ASA - no logging msg 106100 for matching ACEs
Hello all,
At monitoring, real-time log viewer, loggin level debugging, and syslog also, I can't see the message 106100, which each Acess List Entry should generate when there is a match. Some times are generated, but 99% most of the time aren't.
I can see the hit count increasing, but 106100 msgs are not generated. I have logging of each ACE at the default level.
Other messages like 302013,302014 are always generated.
this is my loggin settings
Syslog logging: enabled
    Facility: 20
    Timestamp logging: disabled
    Standby logging: enabled
    Debug-trace logging: disabled
    Console logging: disabled
    Monitor logging: disabled
    Buffer logging: level debugging, 27517332 messages logged
    Trap logging: level informational, facility 20, 23033795 messages logged
        Logging to inside server errors: 221  dropped: 64276
    History logging: disabled
    Device ID: disabled
    Mail logging: disabled
    ASDM logging: level informational, 23033795 messages logged
Any ideas?
thanks
1 REPLY
Re: ASA - no logging msg 106100 for matching ACEs
You didn't say what version of the code you are running - but if if is 8.2.1, there's a known bug CSCsz73284 that may explain your problem.
It's officially fixed (per Cisco) in 8.2.1.12
Hope this helps,
Paul
332
