ASA not allowing connection from Mobile device to CUMA Server
Afternoon security massive,
     Im a voice guy trying( and failing) to get my mobile devices connected to my CUMA server that sits behind my ASA. I can see the Inbound TCP connection attempt here:
6Dec 16 200913:53:0830201389.193.21.11648847192.168.100.1319080Built inbound TCP connection 486 for outside:89.193.21.116/48847 (89.193.21.116/48847) to inside:192.168.100.131/9080 (195.157.156.94/9080)
But then shortly after I recieve the following:
6Dec 16 200913:53:1830201489.193.21.11648847192.168.100.1319080Teardown TCP connection 486 for outside:89.193.21.116/48847 to inside:192.168.100.131/9080 duration 0:00:10 bytes 0 TCP Reset-O
Ive attached a copy of the config on the ASA for your perusal, any comments would be massively appreciated.
C.
1 REPLY
Re: ASA not allowing connection from Mobile device to CUMA Serve
Lets try this.
access-list CAPTUREOUT extended permit tcp any host 195.157.156.94 eq 5443
access-list CAPTUREOUT extended permit tcp any host 195.157.156.94 eq 6532
access-list CAPTUREOUT extended permit tcp any host 195.157.156.94 eq 9080
access-list CAPTUREOUT extended permit tcp host 195.157.156.94 eq 5443 any
access-list CAPTUREOUT extended permit tcp host 195.157.156.94 eq 6532 any
access-list CAPTUREOUT extended permit tcp host 195.157.156.94 eq 9080 any
access-list CAPTUREIN extended permit tcp any host 192.168.100.131 eq 5443
access-list CAPTUREIN extended permit tcp any host 192.168.100.131 eq 6532
access-list CAPTUREIN extended permit tcp any host 192.168.100.131 eq 9080
access-list CAPTUREIN extended permit tcp host 192.168.100.131 eq 5443 any
access-list CAPTUREIN extended permit tcp host 192.168.100.131 eq 6532 any
access-list CAPTUREIN extended permit tcp host 192.168.100.131 eq 9080 any
Capture CAPOUT access-list CAPTUREOUT interface outside
Capture CAPIN access-list CAPTUREIN interface inside
Clear asp drop
Try a couple of times to get the packets from the CUMA and then send us the show asp drop and the show cap CAPOUT and CAPIN.
412
