Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA not allowing ipsec connection started from within network
Is there a way to fix this?
regular translation creation failed for protocol 50 src inside:192.x.x.x dst outside:x.x.x.x
Green
Re: ASA not allowing ipsec connection started from within networ
This error typically means that NAT-T is either not supported or not enabled on the vpn client and the vpn endpoint. Nothing wrong with the ASA.
we are using the at&t global dialer client. Maybe NAT-T is not supported with the client. I will have to check with AT&T
164
