Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA not allowing trace
We have ASA5550 firwalling our LAN from internet,ICMP is open any any both way for test, but when we do trace to a public address on internet , ASA is not showing all the hops along the line. any idea ?
Re: ASA not allowing trace
You need to configure the ASA to decrement the TTL in the traceroute - however there is a security advisory about this, the vulnerability is fixed in software version 7.2(3)6 or 8.0(3) and later.
HTH>
Community Member
Thanks Andy,
Can you send me an example.
Sure - try:-
policy-map global_policy
class class-default
set connection decrement-ttl
HTH>
Community Member
Andy,
We are not doing any Qos on ASA,is this the only way?
We are running verison 8.04 IOS.
That is not QoS configuration - it is amending the default policy that exists in the ASA.
There is no other way to configure the ASA to show itself as a hop in a trace route - the ASA will NOT decrement the TTL unless told to.
Community Member
Thanks Andy,
see my previous post.
286
