Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ASA not encapsulating traffic for IPSEC tunnel
I have an IPSEC tunnel to a vendor who I can reach and i see encaps/decaps. When he tries to ping my IP 192.168.26.10 i decap but can't encap. Can any one assist?
cleaned up config below. Please let me know if anyone wants to see more.
interface GigabitEthernet0/0
 nameif Outside
 security-level 0
 ip address 209.120.152.138 255.255.255.248
interface GigabitEthernet0/1
 nameif Inside
 security-level 90
 ip address 172.31.2.89 255.255.255.252
boot system disk0:/asa841-k8.bin
ftp mode passive
access-list Outside_cryptomap extended permit ip host 10.121.4.2 host 212.247.19.43
access-list Outside_cryptomap extended permit ip host 192.168.25.10 host 212.247.19.43
access-list Outside_cryptomap extended permit ip host 192.168.26.10 host 212.247.19.43
access-list Outside_cryptomap extended permit ip host 209.120.152.138 host 212.247.19.46
nat (Inside,Outside) source dynamic my-inside-net interface
nat (InternetAccess,Outside) source dynamic InternetAccess interface
nat (InternetAccess,Outside) source dynamic Wireless interface
nat (VPN_IN,Outside) source static VPN OBJ-OUTSIDE-NETWORKS
route Outside 0.0.0.0 0.0.0.0 209.120.152.137 1
route InternetAccess 192.168.1.0 255.255.255.0 192.168.51.2 1
route InternetAccess 192.168.9.0 255.255.255.0 192.168.51.2 1
route InternetAccess 192.168.10.0 255.255.255.0 192.168.51.2 1
crypto ipsec ikev1 transform-set officevpn esp-aes-256 esp-sha-hmac
crypto map vendor 1 match address Outside_cryptomap
crypto map vendor 1 set peer 212.247.19.42
crypto map vendor 1 set ikev1 transform-set officevpn
crypto map vendor interface Outside
crypto ikev1 enable Outside
crypto ikev1 policy 1
 authentication pre-share
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
ssl encryption aes256-sha1 aes128-sha1 3des-sha1 des-sha1
webvpn
tunnel-group vendor type ipsec-l2l
tunnel-group 212.247.19.42 type ipsec-l2l
tunnel-group 212.247.19.42 ipsec-attributes
 ikev1 pre-shared-key *****
Show commands
interface: Outside
    Crypto map tag: tbricks, seq num: 1, local addr: 209.120.152.138
      local ident (addr/mask/prot/port): (192.168.26.10/255.255.255.255/0/0)
      remote ident (addr/mask/prot/port): (212.247.19.43/255.255.255.255/0/0)
      current_peer: 212.247.19.42
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 134664, #pkts decrypt: 134664, #pkts verify: 134664
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 209.120.152.138/0, remote crypto endpt.: 212.247.19.42/0
      path mtu 1500, ipsec overhead 74, media mtu 1500
      current outbound spi: DD73567E
      current inbound spi : F5809969
    inbound esp sas:
      spi: 0xF5809969 (4118845801)
         transform: esp-aes-256 esp-sha-hmac no compression
         in use settings ={L2L, Tunnel, }
         slot: 0, conn_id: 16384, crypto-map: tbricks
         sa timing: remaining key lifetime (kB/sec): (3914506/13686)
         IV size: 16 bytes
         replay detection support: Y
         Anti replay bitmap:
          0xFFFFFFFF 0xFFFFFFFF
    outbound esp sas:
      spi: 0xDD73567E (3715323518)
         sa timing: remaining key lifetime (kB/sec): (3915000/13686)
         IV size: 16 bytes
         Anti replay bitmap:
          0x00000000 0x00000001
      local ident (addr/mask/prot/port): (209.120.152.138/255.255.255.255/0/0)
      remote ident (addr/mask/prot/port): (212.247.19.46/255.255.255.255/0/0)
      #pkts encaps: 522, #pkts encrypt: 522, #pkts digest: 522
      #pkts decaps: 585, #pkts decrypt: 585, #pkts verify: 585
      #pkts not compressed: 522, #pkts comp failed: 0, #pkts decomp failed: 0
      current outbound spi: 52B73700
      current inbound spi : 6456A473
    inbound esp sas:
      spi: 0x6456A473 (1683399795)
         sa timing: remaining key lifetime (kB/sec): (3914313/28366)
         IV size: 16 bytes
         Anti replay bitmap:
    outbound esp sas:
      spi: 0x52B73700 (1387738880)
         sa timing: remaining key lifetime (kB/sec): (3914958/28366)
         IV size: 16 bytes
         Anti replay bitmap:
Thank you in advance
Hall of Fame Super Silver
Your cryptomap is pointing to
Your cryptomap is pointing to his public IP addresses (assuming that's the case as they appear to be in the same subnet as his peering address). We would normally use his private addresses as the decapsulation at his end would bypass his ingress NAT.
I thought some similar to
I thought some similar to that but i guess this is how he has it set up with other customers
199
