ASA Outbound Access Problem
good morning guys!
we recently procured an ASA-5510 app. went thru the ASDM Setup wizard with External and Internal config. public and private IP's already established. accdg to the ASA doc, internal clients should be immediately able to get outbound access (internet) by default. doesn't work.
my ISP told me that he can ping my external interface after providing him the MAC. he advised me that i should be able to at least ping up to the gateway.
directly connecting the external line to a PC is ok. browsing and everything.
setup is as follows:
Mgt 0/0 : MANAGEMENT 192.168.1.1 (default), DHCP enabled
Eth 0/0 : EXTERNAL StaticIP/30
Eth 0/1 : INTERNAL 200.200.200.0
PAT selected instead of NAT
Default security policies in effect.
please help.
thanks!
1 REPLY
Re: ASA Outbound Access Problem
You need the following minimum config for interfaces, default route, and PAT. You do not need any ACLs applied for outbound traffic to work.
interface Ethernet0/0
nameif outside
security-level 0
ip address xx.xx.xx.xx 255.255.255.248
no shut
interface Ethernet0/1
nameif inside
security-level 100
ip address 200.200.200.1 255.255.255.0
no shut
route outside 0.0.0.0 0.0.0.0 xx.xx.xx.xx
global (outside) 1 interface
nat (inside) 1 200.200.200.0 255.255.255.0
95
