ASA outside interface ip not reachable from internet.
I have configured asa 5520 (8.2) outside interface ip :125.19.x.x but i am unable to reach from internet. When i troubleshoot with packet-tracer command in firewall below is the output. please let me know what is the issues.
ASA# packet-tracer input outside icmp 112.82.X.X 0 0 144.X.X.X
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   144.X.X.X   255.255.255.255 identity
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 388358900, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
output-status: up
output-line-status: up
Action: drop
Drop-reason: (inspect-icmp-seq-num-not-matched) ICMP Inspect seq num not matched
Everyone's tags (1)
1 REPLY
Hi Rajesh, Do you have
Hi Rajesh,
Do you have inspect icmp enabled in your service policy? if not enable that and try it.
do you have any policies or acl's binded to control-plane? if so remove the control-plane in access-group and enable without control-plane
do you have any icmp configuration in your firewall for outside interface? if so you need to tweak it to allow....
do you have anyother devices next to firewall is blocking icmp echo-reply ?
Karthik
74
