Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA Packet- tracer Problem
Hi ,
I have the following problem when i apply packet tracer command:
Result of the command: "packet-tracer input internal tcp 25 smtp"
Phase: 1
Subtype: input
Result: ALLOW
Additional Information:
Phase: 2
Result: ALLOW
Phase: 3
Subtype: inspect-smtp
Result: ALLOW
Phase: 4
Type: NAT
Result: ALLOW
object network Mail-Server
Static translate to
Phase: 5
Type: NAT
Subtype: rpf-check
Result: ALLOW
nat (INTERNAL,EXTERNAL) after-auto source dynamic OBJ_GENERIC_ALL interface
input-interface: INTERNAL
input-status: up
input-line-status: up
output-interface: EXTERNAL
output-status: up
output-line-status: up
Action: drop
Drop-reason: (sp-security-failed) Slowpath security checks failed
Result of the command: "show running-config"
ASA Version 8.4(5)
interface Ethernet0/0
 nameif INTERNAL
 security-level 100
 ip address
interface Ethernet0/1
 nameif TMG
 security-level 90
 ip address
interface Ethernet0/2
 no nameif
 no security-level
 no ip address
interface Ethernet0/3
 nameif EXTERNAL
 security-level 0
 ip address
interface Management0/0
 nameif management
 security-level 100
 ip address
ftp mode passive
object network OBJ_GENERIC_ALL
access-list EXTERNAL_access extended permit tcp any object Mail-Server eq smtp
pager lines 24
logging asdm informational
mtu INTERNAL 1500
mtu EXTERNAL 1500
mtu management 1500
mtu TMG 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (TMG,EXTERNAL) after-auto source dynamic OBJ_GENERIC_ALL interface
access-group EXTERNAL_access in interface EXTERNAL
route EXTERNAL 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd address management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
: end
My question is what is "sp-security" and why it drop my packets ??
Hello, Here are the reasons
Here are the reasons why the packet might be dropped due to this reason:
   Slowpath security checks failed:
This counter is incremented and packet is dropped when the security appliance is:
  1) In routed mode receives a through-the-box:
    - L2 broadcast packet
    - IPv4 packet with destination IP address equal to
    - IPv4 packet with source IP address equal to
  2) In routed or transparent mode and receives a through-the-box IPv4 packet with:
    - first octet of the source IP address equal to zero
    - source IP address equal to the loopback IP address
    - network part of source IP address equal to all 0's
    - network part of the source IP address equal to all 1's
    - source IP address host part equal to all 0's or all 1's
  3) In routed or transparent mode and receives an IPv4 or IPv6 packet with same source        and destination IP addresses
1 and 2) Determine if an external user is trying to compromise the protected network. Check for misconfigured clients.
3) If this message counter is incrementing rapidly, an attack may be in progress. Use the packet capture feature to capture type asp packets, and check the source MAC address in the packet to see where they are coming from.
1 and 2) 106016
3) 106017
Error Message %ASA-2-106016: Deny IP spoof from ( IP_address ) to IP_address on interface interface_name.
Explanation A packet arrived at the ASA interface that has a destination IP address of and a destination MAC address of the ASA interface. In addition, this message is generated when the ASA discarded a packet with an invalid source address, which may include one of the following or some other invalid address:
  • Loopback network (
  • Broadcast (limited, net-directed, subnet-directed, and all-subnets-directed)
  • The destination host (land.c)
To further enhance spoof packet detection, use the icmp command to configure the ASA to discard packets with source addresses belonging to the internal network, because the access-list command has been deprecated and is no longer guaranteed to work correctly.
Recommended Action Determine if an external user is trying to compromise the protected network. Check for misconfigured clients.
Error Message %ASA-2-106017: Deny IP due to Land Attack from IP_address to IP_address
+ Explanation The ASA received a packet with the IP source address equal to the IP destination, and the destination port equal to the source port. This message indicates a spoofed packet that is designed to attack systems. This attack is referred to as a Land Attack.
+ Recommended Action If this message persists, an attack may be in progress. The packet does not provide enough information to determine where the attack originates.
Please don't forget to rate and mark as correct the Post!
Let me know if there are further questions regarding this
David Castro,
