ASA (policy) NAT help
I think this might a be policy NAT required, but I have never tried this before.
On our LAN we have a subnet 192.168.100.x/24 and this need to get to an IP range of 10.100.0.32/27 which is a remote company network, tyhe thing is they also have a network on 192.168.100.x/24 so I want 192.168.100.x/24 to be NAT'ed to 192.168.90.0/24 only if going to this netork.
Possible
Re: ASA (policy) NAT help
Yes this is possible - you need to use PolicyBased NAT
HTH>
Do you have an example of this.
Inside range he is on is
192.168.100.x/24 and he need to get to 10.100.0.32/27
I want him to be seen as 192.168.90.x/24 or 192.168.90.240 if easier?
The config would be something like:-
access-list <> extended permit ip <> <
static (inside,outside) <> access-list <>
HTH>
access-list policy_NAT permit ip 192.168.100.0 255.255.255.0 host 10.100.0.32
static (inside,outside) 192.168.90.240 access-list policy_NAT
If there is a match in the ACL 'policy_NAT' then the 192.168.100.x address will be translated to 192.168.90.240
hi,
When adding "static (inside,outside) 192.168.90.240 access-list policy_NAT
I seem to get the error:
global address overlaps with mask
Check your ACL.
Use NAT instead:
global (outside) 1 192.168.90.240
nat (inside) 1 access-list policy_NAT
Can host 10.100.0.32 be a range 10.100.0.32/27 ?
Yes
Yes, just take out :
host 10.100.0.32
and replace with
10.100.0.32 255.255.255.224
Tried this but it didn't work, this my fault the interface where this network lives is off acn interface on the ASA called "DMZ3":
access-list policy-nat-2 permit ip 192.168.100.0 255.255.255.0 10.100.0.32 255.255.255.224
global (outside) 2 192.168.90.240
nat (inside) 2 access-list policy-nat-2
You need to detail the error, or why you say it didn't work.
Have you forced the connection from the 192.168.100.0/24 to the 10.100.0.32/27 network?
Does 'show xla' give you a translation?
Sorry that was very brief of me.
I have added this as you know:
the 192.168.100.x is on the inside and 10.100.0.32/27 is on the DMZ3 interfcae on the ASA which is were this WAN is installed to this remote network.
Let me look at the NAT translations.
Then you need to change nat (<>) 2 access-list policy-nat-2
I didn't see any translations:
Does this look ok to you guys, sorry for all the silly confusion I have created.
nat (DMZ3) 2 access-list policy-nat-2
I went to the PC with 192.168.100.x amd pinged 10.100.0.61 which I know is live and got a request timeout.
Config looks OK - can you confirm that layer 3 deivces on the 10.100.0.32/27 subnet know "how" to get "back" to 192.168.90.x thru 192.168.100.x ?
Are you allowing icmp - echo-replies back into the outside interface of the ASA?
192.168.90.x can ping 10.100.0.32/27 as I'm pinging from that subnet.
I guess they will just send replies to 192.168.90.240 that translates to 192.168.100.x?
Is this staic NAT better than a policy NAT?
I think you have your bracketed interfaces the wrong way round for global and nat.
global (DMZ3)
nat (inside)
Sadley, I couldn't get this to work:
I tried these 2 configs:
1.)
global (DMZ3) 2 192.168.90.240
nat (outside) 2 access-list policy-nat-2
When i do a packet trace I get a drop:
packet-tracer input inside icmp 192.168.100.32 0 1 1 10.100$
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in Remotesvr_Servers 255.255.255.224 DMZ3
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in VLAN100 255.255.255.0 inside
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group inside_access_in in interface inside
access-list inside_access_in extended permit icmp any any
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect icmp
service-policy global_policy global
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype:
Result: DROP
Config:
nat (inside) 1 0.0.0.0 0.0.0.0
nat-control
match ip inside any DMZ3 any
dynamic translation to pool 1 (No matching global)
translate_hits = 137, untranslate_hits = 0
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
2.)
access-list inside_outbound_nat0_acl extended permit ip 192.168.100.0 255.255.255.0 10.100.0.32 255.255.255.224
access-list policy-nat-2 extended permit ip 192.168.100.0 255.255.255.0 10.100.0.32 255.255.255.224
static (inside,DMZ3) 192.168.90.240 access-list policy-nat-2
On this one I get the error "global address overlaps with mask"
This will not work - as you are trying to perform PAT in a Static 1:1 config, not possible.
use:-
global (DMZ3) 2 192.168.90.0
or
access-list policy-nat-2 permit ip host 192.168.100.x 10.100.0.32 255.255.255.224
tried those 2 example of yours and tried the packet trace again:
Phase: 8
Type: NAT
Subtype:
Result: DROP
Config:
nat-control
translate_hits = 145, untranslate_hits = 0
Post all your current NAT/Interface config.
I have removed the config that I am trying, but here is some of it, need anything else, I've had to hide some bits:
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address *.*.*.* 255.255.255.224
ospf cost 10
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address *.*.*.* 255.255.0.0
ospf cost 10
interface GigabitEthernet0/2
no nameif
no security-level
no ip address
interface GigabitEthernet0/2.4
vlan 4
nameif DMZ2_Network
security-level 15
ospf cost 10
interface GigabitEthernet0/2.6
vlan 6
nameif DMZ1_Servers
security-level 10
ip address 172.24.0.100 255.255.255.0
ospf cost 10
interface GigabitEthernet0/2.7
vlan 7
nameif DMZ3
security-level 25
ip address 192.168.2.1 255.255.255.0
ospf cost 10
interface GigabitEthernet0/2.9
vlan 9
nameif DMZ6_WAN
security-level 35
ip address 172.30.0.4 255.255.255.0
ospf cost 10
interface GigabitEthernet0/2.10
vlan 10
nameif DMZ10_Servers
security-level 25
ip address 192.168.15.1 255.255.255.224
ospf cost 10
interface GigabitEthernet0/2.300
vlan 300
nameif DMZ4
security-level 20
ip address 172.25.1.1 255.255.255.0
ospf cost 10
interface GigabitEthernet0/3
description LAN/STATE Failover Interface
static (inside,outside) udp interface 9996 SVR06 9996 netmask 255.255.255.255
static (inside,outside) *.*.*.* SVR10 netmask 255.255.255.255
static (inside,outside) DMZ6-172.30.0.0 access-list policy-nat
static (DMZ10_Servers,outside) *.*.*.* SVR05_NEW netmask 255.255.255.255
static (inside,outside) *.*.*.* 192.168.25.42 netmask 255.255.255.255
nat-control
nat (outside) 1 Office1 255.255.255.0
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (DMZ2_Network) 0 access-list DMZ2_nat0_outbound
nat (DMZ2_Network) 1 0.0.0.0 0.0.0.0
nat (DMZ1_Servers) 0 access-list DMZ1_Servers_nat0_outbound
nat (DMZ1_Servers) 0 access-list DMZ_inbound_nat0_acl outside
nat (DMZ1_Servers) 1 0.0.0.0 0.0.0.0
nat (DMZ3) 0 access-list DMZ3_nat0_outbound
nat (DMZ3) 1 0.0.0.0 0.0.0.0
nat (DMZ6_WAN) 0 access-list DMZ6_WAN_nat0_outbound
nat (DMZ6_WAN) 1 0.0.0.0 0.0.0.0
nat (DMZ10_Servers) 0 access-list DMZ10_Servers_nat0_outbound
nat (DMZ10_Servers) 1 0.0.0.0 0.0.0.0
nat (DMZ4) 0 access-list DMZ4_outbound_nat0_acl
nat (DMZ4) 1 0.0.0.0 0.0.0.0
no crypto isakmp nat-traversal
So were is the desination? and what interface is the policy nat required from?
362
