asa priority queue not working
Hi All.
I am going crazy with the Hierarchical priority queuing on asa 5505 .
Basically here is an example of my setup but when I use show service-policy interface outside or the interface name all the class defaults have their counter increased apart from any of the priority queues
Class-map http
Match port tcp eq www
Class-map https
Match port tcp eq https
Class-map default
Match any
Policy-map priority-policy
Class http
Priority
Exit
Policy-map standard-policy
Class default
Shape average 200000 1600
Service-policy priority-policy
Exit
Service-policy standard-policy interface outside
But  all traffics do go through the normal queue which is driving me mad
When I type show service-policy priority nothing comes up
And when typing show service-policy interface outside , the counter for none of the priority classes increase
many thanks
  • Firewalling
Can you share the output of the following command:
show service-policy flow tcp host inside_ip host 4.2.2.2 eq 80
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Thanks very much for this . sorry for the delay but here it is
btw , would I have to enable flow checking on the specific interface and if so how ?
Interface x1:
  Service-policy:priority-policy    Class-map: class-default
      Match: any
      Action:
        Output flow:  Shape average 200000 1600
        Output flow:  police input 2000000 2500 conform-action transmit exceed-action transmit
Interface x2
etc
But what is relevant to the traffic should be interface x1 which shows it but the wrong policy which aplies to all traffic and not the specific policy which applies to the specific port 80 and 443
by the way what is the output that I should expect to see from flow command ?
Also why does it show both as output flow? one should be for download which is the police thus input and one for upload which is the shape command but shows both as output .
Also what plays with my mind is , if the flow command is to tell you which policy the asa is going to apply to it , why does it show the service policy from other interfaces which will not apply to this traffic in any circumstances
The way i have my bandwidth management setup is, I have applied the traffic management on the internal interface and not the internet one thus upload in here means download and vice versa as the internal interface has to pass traffic through the internet interface
You will not see the packets in the standard priority queue if you use Hierarchical priority queuing. Priority packets are sent ahead of all others in your setup, but will not be seen in the counters of a show service-policy priority as that queue is not used. Dont think there is a way to see the trasmitted priority packets using this method, a little trust involved.
You may be better off doing the following so you can be sure your required traffic is hitting the LLQ.
Class default
Exit
Class http
Priority
Class https
Priority
Exit
Service-policy prioirty-policy interface outside
This will of course not shape the priority traffic but you will see the stats.
Using the priority queue is usually for voip etc, which is significantly less traffic than HTTP so you should be sure you want to prioritise this over all else. If the standard prioirty queue is used, this will be serviced first always and if you are sending loads of traffic to this queue you could starve all other comms through the ASA.
Andy
Re: asa priority queue not working
thanks for this, I tried to put the standard queue under priority queue as suggested but didn't work and returned
ERROR: The service-policy (
standard-policy
) that is being installed contains actions other than 'priority'.  Only 'priority' is allowed in a child policy.
I have seen a guide in the internet which suggests this way I am doing it is correct but obviously it is not .
if I take of the service-policy under the standard-policy , all priority queues disappear form the show service-policy but when there the queues show up but the counter does not raise
also it seems like I don't have to enable priority queue interface name in the global config for heirarical queue as is the case with the standard/priority queue so I have not enable it which I don't know If i am making a mistake or not. I did also enabl it but it did not make any difference
Ah Nuts!
sorry my bad
You will need to police the default class, not shape. This does have slightly different permitations in that it will drop traffic that exceeds the police parameter. Its going to be a little bit of a trade off.
You can only shape all and nest priority within that shape.
so:
Class http
Priority
Class https
Priority
Class Default (you may need to use the built in class-default class here, I cannot remember)
Police output 200000 1600
Exit
Service-policy priority-policy interface outside
You cannot shape and use standard priority queueing on the same interface....you can only nest a priority policy in a shape policy which will not use the standard priority queue.
Andy
thanks for this.
I know I did look at the cisco document and read it all and here is aqoute from it
You cannot configure traffic shaping and standard priority queuing for the same interface; only hierarchical priority queuing is allowed."
This means if I used Hierarchical priority queuing I can use shaping which is what I am doing , isn't that correct ?
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/conns_qos.html
You are correct. But what you will not see is the standard priority queue stats as this queue is not used in hierachical priority queuing. You will not be able to see your prioirty packets, although the process is to send these within the shape first.
So if you shape and nest priority, the standard queue is not used, hence why you dont see any hits on the commands you are running. BUT - the ASA should be prioritising your traffic as required.
The config including policing above was to get stats into the priority queue for you to see the difference.
Andy
Thanks for taking time and replying. I am trying to understand this standard vs heirarichal queuing and have a hard time grasping a concept which may be very easy.
Basically I know that asa has two qos mode, standard and heirarchical .
standard has two queues , standard and priority and no shaping is allowed
heirarchical has two queues which are again normal and priority . so when you reference standard in the text above, is that a reference to the heirarchical standard queue or the basic model standard queue.
"But what you will not see is the standard priority queue stats as this queue is not used in hierachical priority queuing"
I don't have standard queue in my config , it is heirarchical which has 2 queues of standard and priority.
what you are explaining is that the traffic is first shapped and then prioritised hence why If i have shaping i can not see the counter go up . I don't understand the comment which says "
the standard queue is not used, hence why you dont see any hits on the commands you are running"
thanks once again
1132
