Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA problem
Dear Sir,
I am having some problem. We have a remote server which is ibm web system manager. From local lan we can access it. but when we try from below ASA we can't get it. I am attaching here two jpg file. And my service policy configuration is like below.
class-map brac-ips-class
match any
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
class brac-ips-class
ips inline fail-open
service-policy global_policy global
Could you please tell me what to check.
Tuhin
Dhaka. BD.
1 REPLY
Re: ASA problem
Can you provide more information about your network set up so that I will be able to understand your issue better and help you. Also check if the routes are configured properly and the access-lists are configured with proper permissions as one of these may be the reason for this issue.
97
