Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA: Question about static public IP accessing
Hi there,
Is it possible to access a server located at the DMZ using its public IP address (static nat), from a server in the same DMZ or another station in another network interface (inside or management)? Will that be possible in the ASA?
My customer states that it can be done on Check Point firewalls.
Any feedback is highly appreciated.
Gold
Re: ASA: Question about static public IP accessing
Green
Yes. But it will be one or the other, not both. It is called destination NAT.
DMZ server public ip = 1.1.1.1
DMZ server ip = 192.168.1.1
To access from inside...
static (dmz,inside) 1.1.1.1 192.168.1.1 netmask 255.255.255.255
To access it from another DMZ machine you must use hairpinning. DNS doctoring will only work if you're trying to resolve it, not using an ip.
Hairpinning Example
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807968d1.shtml#solution2
Community Member
D-NAT is not a option for the customer, since he needs to actually go out and go back in the same interface.
I had used hairpinning for in a VPN client and lan-2-lan environment, but I did'nt think it as a solution for this scenario.
I'll try that and I'll post here again with my findings. Thanks a lot!
Green
"D-NAT is not a option for the customer, since he needs to actually go out and go back in the same interface"
-I posted an example for inside to dmz using d-nat. The other example (hairpin) was for dmz to dmz.
Community Member
Sure, I got it! Thanks again.
240
