ASA redundant failover links
We are setting up a new ASA which is in multi context mode.  I was wondering if it is possible to setup redundant failover and state links?  I know that it is possible to run failover on one link and state on another, or both over the same link, but is it possible to have both failover and state running on 2 links?  For example, failover and state on ten1/0 as well as failover and state on ten1/1.
Hope I have explained my question well enough.  If not I will try to explain better.
thanks
Everyone's tags (3)
1 ACCEPTED SOLUTION
I would suggest to make a redundant logical link and attach two physical links to it. Than during failover link configuration specify your redundant link as a failover link. Not sure if it works but dont see any obstacles for this solution to fail..
Ah, thanks...I had originally tried this but did not find the portchannel as an interface option.  I had overlooked that I had already asigned that portchannel to another context.  Thanks.
899
