ASA Redundant interface
I'm setting up 2 ASAs in failover mode. For added availability I'm using Redundant interfaces.
Ethernet0/0 is a 1Gbps interface
Ethernet0/2 is a 100Mbps interface
Both are combined into Redundant1
The same is ddone for the other 2:
Ethernet0/1 is a 1Gbps interface
Ethernet0/3 is a 100Mbps interface
Both are combined into Redundant2
I use 2 contexts, and each context has it's own Redundant interface
(All other interfaces are through the 4-port RJ45/SFP module).
In both Redundant inrterfaces, the 1Gbps is the primary, and the 100Mbps is the secondary interface.
When configured, all works as expected.
HOWEVER:
When I disconnect the 1Gbps link, a switchover occurs to the secondary (100Mbps) link. Connectivity is maintained.
When I reconnect the 1Gbps link, there is NO switchback! (like the preempt option with context failover).
Ofcourse I prefer the 1Gbps link to be active.
Is there a way to accomplish this?
If not: Is there a SNMP way to monitor this? (I now about the show int Red1 | grep Member and redundant-interface red1 active-member e0/0 commands).
Looking forward to your reply,
Marcel
Bronze
Re: ASA Redundant interface
The security appliance determines the health of the other unit by monitoring the failover link. When a unit does not receive three consecutive hello messages on the failover link, the unit sends interface hello messages on each interface, including the failover interface, to validate whether or not the peer interface is responsive. The action that the security appliance takes depends upon the response from the other unit. See the following possible actions:
•If the security appliance receives a response on the failover interface, then it does not fail over.
•If the security appliance does not receive a response on the failover link, but receives a response on another interface, then the unit does not failover. The failover link is marked as failed. You should restore the failover link as soon as possible because the unit cannot fail over to the standby while the failover link is down.
•If the security appliance does not receive a response on any interface, then the standby unit switches to active mode and classifies the other unit as failed.
If a failed unit does not recover and you believe it should not be failed, you can reset the state by entering the failover reset command. If the failover condition persists, however, the unit will fail again.
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/failover.html#wp1042444
Hi Mvandorp!
Unfortunately there is no preemption mechanisam available for ASA Redundant interface the only option is to use
the command redundant-interface redundant 1 active-member in order to make the Primary Interface
active again.
To check the details refer to the following URLs:
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/interface_start.html#wp1062371
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/intrface.html#wp1062296
1379
