11-30-2011 10:41 PM - edited 03-11-2019 02:57 PM
Hello
Cisco documentation is unclear:
if i have two members in redundant interface both connected to the same switch/vlan, on switch both ports are UP (no shut),
what is a state of physical interfaces on ASA ?
Are both ports UP ? Or ASA shutdown one of the interfaces ? (backup interface)
If both ports are physically UP what traffic is send thru backup interface ?
In case of both ports UP how does the switch know which port is actually working (in case of initiation new flow from switch side, with new/uknown destination mac-address) ?
Thanx
Solved! Go to Solution.
11-30-2011 11:43 PM
Both Interfaces will have the same mac-address but only one will actually pass traffic, so at some point, I think you would be able to see 2 mac-addresses learned on two different ports, hence, the traffic is going to be sent by the switch to both interfaces, of course, only one will actually process the traffic on the ASA.
Mike
11-30-2011 11:43 PM
Mike
