ASA route ping but not TCP packets between two internal LANs
I need to connect two internal LANs each of which has ASA as a firewall to outside. One has ASA 5505 with two interfaces and another - ASA 5510 with three interfaces. I managed to pass echo packets from one internal LAN to another, but not the TCP packets. It must be something simple that I missed. Any help will be highly appreciated! Here is the network diagram:
Here is Config from ASA 5510 (i removed obvious settings to save space):
interface Ethernet0/0
 nameif outside
 security-level 0
 ip address YY.YY.YY.YY 255.255.255.224
interface Ethernet0/1
 nameif inside
 security-level 100
 ip address 192.168.35.1 255.255.255.0
interface Ethernet0/2
 nameif a-02
 security-level 100
 ip address 192.168.30.250 255.255.255.0
interface Ethernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
 domain-name latista.local
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list outside_access_in extended permit icmp any any inactive
access-list a-02_access_in extended permit ip any any
access-list a-02_access_in extended permit icmp any any inactive
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit icmp any any inactive
access-list inside_access_out extended permit ip any any
access-list inside_access_out extended permit icmp any any inactive
access-list inside_nat0_outbound_1 extended permit ip 192.168.35.0 255.255.255.0 192.168.30.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.35.0 255.255.255.0 192.168.30.0 255.255.255.0
access-list a-02_nat0_outbound extended permit ip 192.168.30.0 255.255.255.0 192.168.35.0 255.255.255.0
access-list a-02_nat0_outbound_1 extended permit ip 192.168.30.0 255.255.255.0 192.168.35.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu a-02 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 0 access-list inside_nat0_outbound_1 outside
nat (a-02) 0 access-list a-02_nat0_outbound
nat (a-02) 0 access-list a-02_nat0_outbound_1 outside
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
access-group inside_access_out out interface inside
access-group a-02_access_in in interface a-02
router rip
 version 1
route outside 0.0.0.0 0.0.0.0 205.251.79.33 1
route inside 192.168.30.0 255.255.255.0 192.168.30.250 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
http 192.168.35.0 255.255.255.0 inside
http 67.208.89.64 255.255.255.224 outside
http 4.26.115.0 255.255.255.240 outside
http 192.168.30.0 255.255.255.0 a-02
http 192.168.20.0 255.255.255.0 a-02
http 96.255.26.199 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect http
service-policy global_policy global
On another ASA (ASA 5505) I only configured the Routing and NAT Exemption. Here is that portion:
access-list inside_nat0_outbound extended permit ip NET_COLO_INT 255.255.255.0 192.168.35.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.35.0 255.255.255.0 NET_COLO_INT 255.255.255.0
route inside 192.168.35.0 255.255.255.0 192.168.30.250 1
Please help!
1 ACCEPTED SOLUTION
Re: ASA route ping but not TCP packets between two internal LANs
Hello Anatoly,
So the TCP state-bypass did it!
Great to hear everything is working, please mark the question as answered so as you said future users can view the solution of this.
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Anatoly,
I would remove these nat statements and this static route
no nat (a-02) 0 access-list a-02_nat0_outbound_1 outside
no nat (inside) 0 access-list inside_nat0_outbound_1 outside
no route inside 192.168.30.0 255.255.255.0 192.168.30.250 1
Now please provide the following packet tracer outputs from Asa 5510
packet-tracer input inside tcp 192.168.35.15 1025 192.168.30.47 80
packet-tracer input a-02 tcp 192.168.30.47 1025 192.168.35.15 80
Julio
Julio Carvajal
Julio, thank you for the answering! Here is the packet tracers info. I ran tracers without removing Route and Nat Exemptions. I will remove them and create another reply with results as well...
Result of the command: "packet-tracer input inside tcp 192.168.35.15 1025 192.168.30.47 80"
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   192.168.30.0    255.255.255.0   a-02
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect http
Phase: 5
Type: NAT-EXEMPT
Subtype:
Result: ALLOW
Config:
  match ip inside 192.168.35.0 255.255.255.0 a-02 192.168.30.0 255.255.255.0
    NAT exempt
    translate_hits = 101, untranslate_hits = 0
Phase: 6
Type: NAT-EXEMPT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 3230, packet dispatched to next module
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: a-02
output-status: up
output-line-status: up
Action: allow
---------------------------- here is the second one ----------------------
Result of the command: "packet-tracer input a-02 tcp 192.168.30.47 1025 192.168.35.15 80"
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.35.0    255.255.255.0   inside
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect http
Phase: 5
Type: NAT-EXEMPT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 6
Type: NAT-EXEMPT
Subtype:
Result: ALLOW
Config:
  match ip a-02 192.168.30.0 255.255.255.0 inside 192.168.35.0 255.255.255.0
    NAT exempt
    translate_hits = 1, untranslate_hits = 104
Phase: 7
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 3236, packet dispatched to next module
Result:
input-interface: a-02
input-status: up
output-interface: inside
output-status: up
Action: allow
I will wait for the other post
Julio Carvajal
I was not able to remove ROUTE - ASA gave error stating Cannnot remove Connected Route. Here are results of tracers without NAT rules:
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect http
Phase: 5
Type: NAT-EXEMPT
Subtype:
Result: ALLOW
Config:
    NAT exempt
    translate_hits = 1, untranslate_hits = 0
Phase: 6
Type: NAT-EXEMPT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 3248, packet dispatched to next module
Result:
input-status: up
output-status: up
Action: allow
-------------------- Here is the second one ---------------------
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect http
Phase: 5
Type: NAT-EXEMPT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 6
Type: NAT-EXEMPT
Subtype:
Result: ALLOW
Config:
    NAT exempt
Phase: 7
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 3250, packet dispatched to next module
Result:
input-status: up
output-status: up
Action: allow
hmm on the packet tracer everything is fine.
Lets do a capture from the host 192.168.35.2 to the host 192.168.30.2
access-list capture permit ip host 192.168.35.2 host 192.168.30.2
access-list capture permit ip host 192.168.30.2 host 192.168.35.2
capture capin access-list capture interface inside
capture capa-02 access-list capture interface a-02
Now I want you to generate some TCP traffic between those hosts.
Then please go to a browser on the inside interface and do the following
https://192.168.30.250/capture/capin/pcap
https://192.168.30.250/capture/capa-02/pcap
And please upload to this case the two files you will get.
Do rate if helps
Julio
Julio Carvajal
you mentioned that I should use browser in "inside" interface (which is 192.168.35.0 net) - it didn't connect to the firewall. I did it from a-02 net (192.168.30.0) and it did. Although both files had size 0 (e.g. were empty).
My bad -  I haven't actually put any traffic through! Let me do that real quick...
No - still size is 0. I was trying to initiate RDP connection from both sides (TCP 3389) and also did PING. Ping went fine, RDP session timed out. But neither made those pcap had any data in them.
Hello Anatolly,
If you do a sh capture capin and show capture capa-02 on the ASA what do you see?
One question you send the ping and the RDP request ( between hosts 192.168.30.2 and 192.168.35.2)
Can I see the capture and ACL configuration for the capture?
Julio Carvajal
Good point - it was actually NOT between those. I just did it again for these two IPs. Here is capture for both captures:
asa5510# show capture capa-02
14 packets captured
   1: 13:48:29.135704 192.168.35.2 > 192.168.30.2: icmp: echo request
   2: 13:48:29.136070 192.168.30.2 > 192.168.35.2: icmp: echo reply
   3: 13:48:30.132698 192.168.35.2 > 192.168.30.2: icmp: echo request
   4: 13:48:30.132912 192.168.30.2 > 192.168.35.2: icmp: echo reply
   5: 13:48:34.636853 192.168.35.2.4654 > 192.168.30.2.23: S 1810127933:1810127933(0) win 65535
   6: 13:48:37.507893 192.168.35.2.4654 > 192.168.30.2.23: S 1810127933:1810127933(0) win 65535
   7: 13:48:43.523715 192.168.35.2.4654 > 192.168.30.2.23: S 1810127933:1810127933(0) win 65535
   8: 13:49:15.998681 192.168.30.2.54837 > 192.168.35.2.23: S 4043652038:4043652038(0) win 5840
35 0,nop,wscale 7>
   9: 13:49:15.999093 192.168.35.2.23 > 192.168.30.2.54837: R 661765980:661765980(0) ack 4043652039 win 0
  10: 13:49:20.155768 192.168.30.2.39499 > 192.168.35.2.3389: S 824236920:824236920(0) win 5840
74 0,nop,wscale 7>
  11: 13:49:20.156150 192.168.35.2.3389 > 192.168.30.2.39499: S 1344822113:1344822113(0) ack 824236921 win 16384
ale 0,nop,nop,timestamp 0 0,nop,nop,sackOK>
  12: 13:49:20.156363 192.168.30.2.39499 > 192.168.35.2.3389: R 2366458597:2366458597(0) win 0
  13: 13:49:22.462607 192.168.35.2.3389 > 192.168.30.2.39499: S 1344822113:1344822113(0) ack 824236921 win 16384
  14: 13:49:23.154151 192.168.30.2.39499 > 192.168.35.2.3389: S 233265947:233265947(0) win 5840
24 0,nop,wscale 7>
14 packets shown
asa5510# show capture capain
ERROR: Capture does not exist
asa5510# show capture capin
15 packets captured
   1: 13:48:29.135552 192.168.35.2 > 192.168.30.2: icmp: echo request
   2: 13:48:29.136208 192.168.30.2 > 192.168.35.2: icmp: echo reply
   3: 13:48:30.132683 192.168.35.2 > 192.168.30.2: icmp: echo request
   5: 13:48:34.636655 192.168.35.2.4654 > 192.168.30.2.23: S 581861776:581861776(0) win 65535
   6: 13:48:37.507862 192.168.35.2.4654 > 192.168.30.2.23: S 581861776:581861776(0) win 65535
   7: 13:48:43.523669 192.168.35.2.4654 > 192.168.30.2.23: S 581861776:581861776(0) win 65535
   8: 13:49:15.998895 192.168.30.2.54837 > 192.168.35.2.23: S 964875669:964875669(0) win 5840
0,nop,wscale 7>
   9: 13:49:15.999032 192.168.35.2.23 > 192.168.30.2.54837: R 0:0(0) ack 964875670 win 0
  10: 13:49:20.155967 192.168.30.2.39499 > 192.168.35.2.3389: S 2181402077:2181402077(0) win 5840
4674 0,nop,wscale 7>
  11: 13:49:20.156089 192.168.35.2.3389 > 192.168.30.2.39499: S 290418727:290418727(0) ack 2181402078 win 16384
  12: 13:49:22.462561 192.168.35.2.3389 > 192.168.30.2.39499: S 290418727:290418727(0) ack 2181402078 win 16384
  13: 13:49:29.025251 192.168.35.2.3389 > 192.168.30.2.39499: S 290418727:290418727(0) ack 2181402078 win 16384
  14: 13:50:05.156806 192.168.30.2.39499 > 192.168.35.2.3389: S 1438335957:1438335957(0) win 5840
5924 0,nop,wscale 7>
  15: 13:50:05.156928 192.168.35.2.3389 > 192.168.30.2.39499: S 302100830:302100830(0) ack 1438335958 win 16384
15 packets shown
Here is the capture ACL info:
access-list capture extended permit ip host 192.168.35.2 host 192.168.30.2
access-list capture extended permit ip host 192.168.30.2 host 192.168.35.2
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu a-02 1500
mtu management 1500
no failover
arp timeout 14400
Hello Anatoly,
So we are almost done here.
please provide the following capture
capture asp type asp-drop all
then provide the show capture asp | include 192.168.30.2
then provide the show capture asp | include 192.168.35.2
and also :
Julio Carvajal
Julio,
Here is printout from capture commands in ASA shell:
asa5510(config)# capture asp type asp-drop all
asa5510(config)# show capture asp | include 192.168.30.2
asa5510(config)# show capture asp | include 192.168.35.2
   1: 14:54:02.191625 192.168.35.2.138 > 192.168.35.255.138:  udp 201 Drop-reason: (acl-drop) Flow is denied by configured rule
asa5510(config)#
Files also attached below (pcap from capin and pcap2 is from capa-02)
Thanks!
- Anatoliy
Here is some more from those two new captures after generating traffic (I was attempting to telnet from 192.168.30.2 to 192.168.35.2 port 3389):
asa5510# show capture asp | include 192.168.30.2
   2: 14:54:15.457495 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
   3: 14:54:31.464957 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
   4: 14:54:32.656948 192.168.30.9.138 > 192.168.30.255.138:  udp 204 Drop-reason: (acl-drop) Flow is denied by configured rule
   5: 14:54:47.477621 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
   6: 14:55:03.493413 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
   7: 14:55:10.272950 192.168.30.25.138 > 192.168.30.255.138:  udp 201 Drop-reason: (acl-drop) Flow is denied by configured rule
   8: 14:55:19.515583 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
   9: 14:55:35.512088 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  10: 14:55:51.528994 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  11: 14:56:07.551225 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  12: 14:56:23.561860 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  13: 14:56:23.561997 192.168.30.2.138 > 192.168.30.255.138:  udp 236 Drop-reason: (acl-drop) Flow is denied by configured rule
  14: 14:56:39.564271 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  16: 14:56:50.015349 192.168.30.23.138 > 192.168.30.255.138:  udp 215
  17: 14:56:55.586746 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  18: 14:57:05.585602 192.168.30.2.137 > 192.168.30.255.137:  udp 50 Drop-reason: (acl-drop) Flow is denied by configured rule
  19: 14:57:05.585647 192.168.30.2.137 > 192.168.30.255.137:  udp 50 Drop-reason: (acl-drop) Flow is denied by configured rule
  20: 14:57:07.585678 192.168.30.2.137 > 192.168.30.255.137:  udp 50 Drop-reason: (acl-drop) Flow is denied by configured rule
  21: 14:57:07.585724 192.168.30.2.137 > 192.168.30.255.137:  udp 50 Drop-reason: (acl-drop) Flow is denied by configured rule
  22: 14:57:11.593170 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  23: 14:57:27.600081 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  27: 14:57:43.621977 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  28: 14:57:44.483159 192.168.30.7.138 > 192.168.30.255.138:  udp 201 Drop-reason: (acl-drop) Flow is denied by configured rule
  29: 14:57:54.962505 192.168.30.19.137 > 192.168.30.255.137:  udp 50 Drop-reason: (acl-drop) Flow is denied by configured rule
  30: 14:57:59.533450 192.168.30.14.137 > 192.168.30.255.137:  udp 50
  31: 14:57:59.629087 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  32: 14:58:01.953945 192.168.30.6.137 > 192.168.30.255.137:  udp 50 Drop-reason: (acl-drop) Flow is denied by configured rule
  33: 14:58:08.341031 192.168.30.9.138 > 192.168.30.255.138:  udp 201
  34: 14:58:09.391916 192.168.30.11.138 > 192.168.30.255.138:  udp 201
  36: 14:58:15.048200 192.168.30.6.138 > 192.168.30.255.138:  udp 201 Drop-reason: (acl-drop) Flow is denied by configured rule
  37: 14:58:15.636365 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  40: 14:58:31.657818 192.168.30.21.138 > 192.168.30.255.138:  udp 209
  43: 14:58:47.664577 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  46: 14:59:03.670650 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  49: 14:59:19.692331 192.168.30.21.138 > 192.168.30.255.138:  udp 209 Drop-reason: (acl-drop) Flow is denied by configured rule
  52: 14:59:35.700006 192.168.30.21.138 > 192.168.30.255.138:  udp 209
  53: 14:59:51.707284 192.168.30.21.138 > 192.168.30.255.138:  udp 209
  56: 15:00:07.744712 192.168.30.21.138 > 192.168.30.255.138:  udp 209
  57: 15:00:07.744849 192.168.30.8.138 > 192.168.30.255.138:  udp 236
  59: 15:00:23.750052 192.168.30.21.138 > 192.168.30.255.138:  udp 209
  60: 15:00:39.757285 192.168.30.21.138 > 192.168.30.255.138:  udp 209
  61: 15:00:55.779226 192.168.30.21.138 > 192.168.30.255.138:  udp 209
  62: 15:01:11.779653 192.168.30.21.138 > 192.168.30.255.138:  udp 209
  63: 15:01:14.614149 192.168.30.2.51264 > 192.168.35.2.3389: R 3892349827:3892349827(0) win 0
  64: 15:01:17.612135 192.168.30.2.51264 > 192.168.35.2.3389: S 3356852894:3356852894(0) win 5840
3977 0,nop,wscale 7>
  65: 15:01:17.767736 192.168.30.2.51264 > 192.168.35.2.3389: R 4049166377:4049166377(0) win 0
  66: 15:01:23.612471 192.168.30.2.51264 > 192.168.35.2.3389: S 2757161395:2757161395(0) win 5840
5477 0,nop,wscale 7>
  67: 15:01:24.330457 192.168.30.2.51264 > 192.168.35.2.3389: R 3449474878:3449474878(0) win 0
  68: 15:01:27.792561 192.168.30.21.138 > 192.168.30.255.138:  udp 209
  69: 15:01:35.613219 192.168.30.2.51264 > 192.168.35.2.3389: S 2979565878:2979565878(0) win 5840
8477 0,nop,wscale 7>
asa5510# show capture asp | include 192.168.35.2
  24: 14:57:40.588928 192.168.35.2.137 > 192.168.35.255.137:  udp 50 Drop-reason: (acl-drop) Flow is denied by configured rule
  25: 14:57:41.338819 192.168.35.2.137 > 192.168.35.255.137:  udp 50 Drop-reason: (acl-drop) Flow is denied by configured rule
  26: 14:57:42.088862 192.168.35.2.137 > 192.168.35.255.137:  udp 50 Drop-reason: (acl-drop) Flow is denied by configured rule
based on the ASA ASP capture, we can see that the ASA is only dropping packets on port 209 and 50 UPD between those two hosts, so no packets being dropped for the RDP or telnet traffic..
Now on the other captures, we can see the host 192.168.30.2 sends a SYN packet, then the 192.168.35.2 responds with a SYN ACK, and the 192.168.30.2 never responds with the ACK so the three way handshake never happens and the connection does not get stablished, this regarding the RDP connection.
On the Telnet connection, we can see that the host 192.168.30.2 sends a SYN packet, and the host 192.168.35.2 responds with a RST ACK so the connection gets closed due to this message from 192.168.35.2
We can see the same packets on both interfaces so that means the ASA is only traversing the traffic at it should in this case..
Julio Carvajal
In other words you are saying that from ASA standpoint it works. Then what else can be not working? Why I still can't do RDP or SSH between these two networks? Any suggestions?
Correct the ASA is sending the traffic on both interfaces.
Becuase the host are refusing this connection.
You can do a capture on each of the hosts while you send the traffic.
Please install wireshark on both servers and catch the traffic, so then we will see if there is any difference between the traffic capture on the ASA.
Julio
Julio Carvajal
OK. Here are the files. Two first are from ASA (pcap and pcap2 from capin and capa-02) and third one - from Wireshark installed on 192.168.35.2. All three were capturing the same flow which I initiated from 192.168.30.2 by using command "telnet 192.168.35.2 3389".
We are missing the capture on the 192.168.30.2!
On these ones I can tell you that there is just a syn, and syn ack. the host 192.168.30.2 is not sending a syn ack. If on the capture on that host we do not see that packet, it will mean the Server (30.2) is not working as properly unless on that particular connection because he is not establishing the connection.
Julio
Julio Carvajal
OK. I am going to use another host instead of 30.2 - it is Linux computer and it will be pain to install Wireshark there. I will re-configure capture on ASA to use another host in 30.x network and re-do the whole capturing thing. Will take a few minutes...
Here we go. I initiated the RDP on 30.3 to 35.2. Traces from both windows boxes as well as capin and capa-02 (pcap and pcap2). Files from ASA may had some old traces from 30.2, though...
I just need it the one on the 30.x network..
As you can see on wireshark.
The host sends a syn packet to the destination, he receives a syn ack.
Then he closes the connection with a RST packet (Reset), that is why we see another SYN ACK from the other site, because the host on the other site is waiting for the final ACK.
Then we see another Syn packet , so the connection is gona be built again until the same happens one more time.
Issue is on host 30.x network. Why are they sending the RST packet, why are they not sending the ACK so the connection get established is not an ASA issue.
Julio
Julio Carvajal
Julio,
Do you think it is ASA 5505 which governs 30.x network? It has quite hairy setup - it manages two site-to-site VPNs as well as L2TP-IPsec Remove Access VPN. I can attach its setup - but it is quite lengthy. Another point might be - the license on that 5505 - it says it only support two interfaces - do you think it might specifically kill TCP packets for the third network? Here is "show version" from ASA 5505:
Cisco Adaptive Security Appliance Software Version 8.2(2)
Device Manager Version 6.2(5)
Compiled on Mon 11-Jan-10 14:19 by builders
System image file is "disk0:/asa822-k8.bin"
Config file at boot was "startup-config"
asa-colo up 67 days 23 hours
Hardware:   ASA5505, 256 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.04
0: Int: Internal-Data0/0    : address is 0021.a0b4.eecb, irq 11
1: Ext: Ethernet0/0         : address is 0021.a0b4.eec3, irq 255
2: Ext: Ethernet0/1         : address is 0021.a0b4.eec4, irq 255
3: Ext: Ethernet0/2         : address is 0021.a0b4.eec5, irq 255
4: Ext: Ethernet0/3         : address is 0021.a0b4.eec6, irq 255
5: Ext: Ethernet0/4         : address is 0021.a0b4.eec7, irq 255
6: Ext: Ethernet0/5         : address is 0021.a0b4.eec8, irq 255
7: Ext: Ethernet0/6         : address is 0021.a0b4.eec9, irq 255
8: Ext: Ethernet0/7         : address is 0021.a0b4.eeca, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Licensed features for this platform:
Maximum Physical Interfaces    : 8
VLANs                          : 3, DMZ Restricted
Inside Hosts                   : 50
Failover                       : Disabled
VPN-DES                        : Enabled
VPN-3DES-AES                   : Enabled
SSL VPN Peers                  : 2
Total VPN Peers                : 10
Dual ISPs                      : Disabled
VLAN Trunk Ports               : 0
Shared License                 : Disabled
AnyConnect for Mobile          : Disabled
AnyConnect for Cisco VPN Phone : Disabled
AnyConnect Essentials          : Disabled
Advanced Endpoint Assessment   : Disabled
UC Phone Proxy Sessions        : 2
Total UC Proxy Sessions        : 2
Botnet Traffic Filter          : Disabled
This platform has a Base license.
What is the default gateway of the server on the 30.x network. I do not think is the ASA 5505 as we are seeing the packets arriving to the ASA 5510. I do think the problem its on the server as ICMP is working properly between two networks.
I mean we saw the TCP RST being generated on the Server, that is all we need it to know to be 100 % is the Server not any of the ASAs.
As ICMP is working, other protocols are going to work, do not know why that server is sending that reset but you could try to use FTP,SSH,TFTP just to confirm that the connection is okay.
Julio
Julio Carvajal
Julio,
I tried SSH and telnet - neither work with the same result. On 30.x network's ASA (5505) when I initiate connection on 30.3 server in ASA 5505 log I see it builds TCP connection and then almost immediately tears it down (LEELA is a 192.168.30.3 server):
6          Jan 06 2012  20:24:53        302013          LEELA 53370            192.168.35.2 3389   Built inbound TCP connection 19053911 for inside:LEELA/53370 (LEELA/53370) to inside:192.168.35.2/3389 (192.168.35.2/3389)
6          Jan 06 2012  20:24:53        302014          LEELA 53370            192.168.35.2 3389   Teardown TCP connection 19053911 for inside:LEELA/53370 to inside:192.168.35.2/3389 duration 0:00:00 bytes 0 TCP Reset-O
Does this make sense?
30.3 server has 192.168.30.1 as a default gateway (which is "inside" interface of that ASA 5505 in 30.x network).
- Anatoliy
Good to know that! that is new info, but the thing is that we still see the reset packet being created on the Server so of course the connection is going to be dropped, the ASA will see the reset and he will drop the connection because he received a Reset packet from the ssh or telnet client.
What if you set the default gateway to be the 5510, can you do it just as a test.
Julio
Julio Carvajal
Ha! It looks like I solved the problem. I manually added route path on that 30.3 server to route 35.0 traffic to 30.250 ip and it started working like charm. Apparently ASA 5505 even it had static route - it ignored it and was not routing packets.
Now another big question - how should I manage that routing? I cannot manually add static route to all servers in 30.0 network...
Can I see the ASA 5505 configuration, you can take some information we do not need to make it shorter (VPN,etc)
Edit: Time to troubleshoot the 5505 Think I know what is happening here
Julio
Julio Carvajal
Here is the most of the config (I took out some sensitive lines - mostly object definitions) - I hope I didn't take lines which are relevant to this problem we are trying to solve :
: Saved
ASA Version 8.2(2)
interface Vlan1
nameif inside
security-level 100
ip address ASA-COLO 255.255.255.0
ospf cost 10
interface Vlan2
nameif outside
security-level 0
ip address ASA-COLO_EXT 255.255.255.224
ospf cost 10
switchport access vlan 2
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
access-list outside_access_in extended deny ip object-group DM_INLINE_NETWORK_25 any
access-list outside_access_in remark trusted services
access-list outside_access_in extended permit object-group DM_INLINE_PROTOCOL_2 object-group TRUSTED any
access-list outside_access_in remark Just in case
access-list outside_access_in extended permit object-group DM_INLINE_PROTOCOL_3 object-group DM_INLINE_NETWORK_9 any
access-list outside_access_in remark Web apps front-end apache
access-list outside_access_in extended permit tcp any object-group DM_INLINE_NETWORK_11 object-group DM_INLINE_TCP_7
access-list outside_access_in remark Extranet and Project Server 2010
access-list outside_access_in extended permit tcp any object-group DM_INLINE_NETWORK_23 eq www
access-list outside_access_in remark Client Hosting HTTP front-end
access-list outside_access_in extended permit tcp any object-group DM_INLINE_NETWORK_24 object-group DM_INLINE_TCP_11
access-list outside_access_in remark Incoming Mail (spam-filter)
access-list outside_access_in extended permit tcp any object-group DM_INLINE_NETWORK_12 eq smtp
access-list outside_access_in extended permit tcp any object-group DM_INLINE_NETWORK_20 eq smtp
access-list outside_access_in remark External DNS
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_1 any object-group DM_INLINE_NETWORK_13
access-list outside_access_in remark FTP
access-list outside_access_in extended permit tcp any object-group DM_INLINE_NETWORK_29 object-group DM_INLINE_TCP_12 inactive
access-list outside_access_in extended permit udp any object-group DM_INLINE_NETWORK_30 range 30000 30100 inactive
access-list outside_access_in remark FTP temporary
access-list outside_access_in remark Linux SSH access
access-list outside_access_in extended permit tcp object-group TRUSTED object-group DM_INLINE_NETWORK_18 eq ssh
access-list outside_access_in remark All mail services
access-list outside_access_in extended permit tcp any object-group DM_INLINE_NETWORK_14 object-group DM_INLINE_TCP_8
access-list outside_access_in extended permit icmp object-group DM_INLINE_NETWORK_22 any
access-list global_access extended permit ip host TISHIN_HOME any
access-list inside_nat0_outbound extended permit ip NET_COLO_INT 255.255.255.0 object-group DM_INLINE_NETWORK_15
access-list outside_cryptomap_1 extended permit ip NET_COLO_INT 255.255.255.0 NET_OFFICE_INT 255.255.255.0
access-list outside_cryptomap_2 extended permit ip NET_COLO_INT 255.255.255.0 NET_OBN_INT 255.255.255.0
access-list outside_cryptomap_3 extended permit ip NET_COLO_INT 255.255.255.0 NET_LT_INT 255.255.255.0
access-list outside_nat0_outbound extended permit ip object-group DM_INLINE_NETWORK_16 NET_COLO_INT 255.255.255.0
pager lines 24
flow-export destination inside NIBBLER 6343
mtu inside 1500
mtu outside 1500
ip local pool l2tp_pool 192.168.30.176-192.168.30.192 mask 255.255.255.224
ip local pool l2tp_pool2 192.168.30.193-192.168.30.209
ip verify reverse-path interface outside
icmp permit any inside
icmp permit any outside
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 NET_COLO_INT 255.255.255.0
nat (outside) 0 access-list outside_nat0_outbound
static (inside,outside) WWWWWWWW WWWWWWWW netmask 255.255.255.255
static (inside,outside) WWWWWWWW2 WWWWWWWW netmask 255.255.255.255
router rip
version 1
route outside 0.0.0.0 0.0.0.0 XX.XX.XX.XX 1
aaa-server RADIUS protocol radius
aaa-server RADIUS (inside) host LEELA
key *****
radius-common-pw *****
nac-policy DfltGrpPolicy-nac-framework-create nac-framework
reval-period 36000
sq-period 300
aaa authentication http console LOCAL
http server enable
http NET_COLO_INT 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 inside
snmp-server community *****
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association replay disable
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set TRANS_ESP_3DES_SHA
crypto map outside_map 1 match address outside_cryptomap_1
crypto map outside_map 1 set transform-set ESP-3DES-MD5
crypto map outside_map 2 match address outside_cryptomap_2
crypto map outside_map 2 set peer OB_EXT
crypto map outside_map 2 set transform-set ESP-3DES-MD5
crypto map outside_map 3 match address outside_cryptomap_3
crypto map outside_map 3 set peer LT_EXT
crypto map outside_map 3 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.0.0 255.255.0.0 inside
telnet timeout 5
ssh 192.168.0.0 255.255.0.0 inside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.30.129-192.168.30.163 inside
dhcpd dns NIBBLER LISA interface inside
dhcpd wins NIBBLER LISA interface inside
dhcpd enable inside
no threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server LISA
webvpn
group-policy DfltGrpPolicy attributes
vpn-simultaneous-logins 10
vpn-tunnel-protocol IPSec svc
password-storage enable
re-xauth enable
ipsec-udp enable
nac-settings value DfltGrpPolicy-nac-framework-create
webvpn
  svc keepalive none
  svc dpd-interval client none
  svc dpd-interval gateway none
  svc compression deflate
  customization value DfltCustomization
group-policy L2TP_Policy internal
group-policy L2TP_Policy attributes
wins-server value 192.168.30.14
dns-server value 192.168.30.14
vpn-tunnel-protocol l2tp-ipsec
split-tunnel-network-list none
address-pools value l2tp_pool
tunnel-group DefaultRAGroup general-attributes
address-pool l2tp_pool
authentication-server-group RADIUS
default-group-policy L2TP_Policy
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *****
isakmp keepalive disable
tunnel-group DefaultRAGroup ppp-attributes
no authentication chap
authentication ms-chap-v2
tunnel-group XX.XX.XX.XX type ipsec-l2l
tunnel-group XX.XX.XX.XX ipsec-attributes
no tunnel-group-map enable peer-ip
class-map global-class
class-map type inspect ftp match-all FTP-class-map
parameters
policy-map global-policy
class global-class
  inspect ftp
  inspect http
service-policy global-policy global
smtp-server 192.168.30.23 192.168.30.2
prompt hostname context
service call-home
2430
