ASA SM and 6513-E VSS
I'm integrating 2 ASA SM running under ASA OS 9.1.2 - Active/standby/multiple contexts on a 6513-E - VSS multiple layer core switch.
Failover and LAN Failover have been archieve via 2 direct connexions between the 2 chassis 6513-E (2 differents vlan).
In this configuration, when I cut the power on the active ASA SM thanks to the command no power enable switch 1 slot 13, stateful failover seems not to work (the witness FTP session was down for ever)...
Your advices and experience are wellcome !!!
Thanks a lot
VSS configuration
firewall autostate
firewall switch 1 module 13 vlan-group 11,12,13
firewall switch 2 module 13 vlan-group 11,12,13
firewall vlan-group 11  301,302  ! (failover vlan and lan failover vlan)
firewall vlan-group 12  12,210,310-314
ASA SM configuration
failover
failover lan unit primary
failover lan interface FOLINK Vlan301
failover polltime unit 5 holdtime 15
failover key *****
failover link STATE_FOLINK Vlan302
failover interface ip FOLINK 172.26.30.1 255.255.255.252 standby 172.26.30.2
failover interface ip STATE_FOLINK 172.26.30.9 255.255.255.252 standby 172.26.30.10
failover group 1
  replication http
344
