Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA SSH issue
Dear CSC,
I just stumbled upon a strange ASA / SSH problem.
First of all some specs:
ASA 5520 - Active /Standby Multi Context mode running 8.4.3
I’ve configured SSH login with local authentication and it works fine if I permit access from anywhere.
I wanted to tighten management access to the MGMT interface and MGMT network and applied the following SSH access restriction
ssh MGMT
MGMT Interface IP address is (2) and ssh client was
Surprisingly I could not connect to the ASA anymore. I than changed to configuration to
Ssh MGMT - it was still not working
So I’ve opened the access to
Ssh MGMT and it worked!
Has anyone an explanation for this? Did I miss anything?
Thanks in advance
Everyone's tags (3)
ASA SSH issue
Well the only explanation I can think of at this moment is that the subnet from where you were doing SSH is not the same as defined on the ASA, can you check the IP from where you are accessing it.
Thanks, Varun Rao Security Team, Cisco TAC
Community Member
Re: ASA SSH issue
Hey Varoun
Just checked it again –
that was my first thought but well as mentioned ASA is using (2)/28 and the client was using in fact I could see the following log entry:
302013 - Build inbound TCP connection 564479 for MGMT: ( to identity (
So basically my ssh connection reached the ASA but never got processed until I changed the allowed ssh IPs.
I'll check tonight in my lab if this issue comes up on other devices.
Cheers Michael
