ASA, startup-config problems
Hi all,
Friends, i tried to config a new ASA 5505, with my old startip-config... I transfer ,,startup-config'' from tstf server OK... but when i reloaded ASA FW the nothing changed...
I think that something need with confreg... maybe its new one (ASA 5505) and something need more what i dont know...
regards ))
Silver
Re: ASA, startup-config problems
Hi ,
I'm not sure what procedure did you follow. Here is what needs to be done-
Assuming that your config file is old-config.cfg.
Step 1) Copy "old-config.cfg" to ASA flash.
Step 2) Use command "copy old-config.cfg startup-config"
Step 3) Reload using "reload" command.
Note: Do not use "Write Mem" command here.
Hope that helps.
Vibhor.
great TNX... if it will help me i make a note fro U ... thank U once more time :))))
395
