ASA stuck on Loading disk0:/asa913-k8.bin...
I have an ASA 5505 (128mb flash, 512mb).  It was on firmware 8.2.1 so I downloaded 8.4.7 and 9.1.3 and put them in the disk0.  I then set the boot image to be 8.4.7 to upgrade to that first and hit reload, but to my shock it started with the 9.1.3 firmware, now it is some sort of loop, see below.  Can I power cycle into Rommon mode and change the boot?
Launching BootLoader...
Boot configuration file contains 2 entries.
Loading disk0:/asa913-k8.bin... Booting...
Platform ASA5505
Loading...
IO memory blocks requested from bigphys 32bit: 9956
CISCO SYSTEMS
Embedded BIOS Version 1.0(12)13 08/28/08 15:50:37.45
Low Memory: 632 KB
High Memory: 507 MB
PCI Device Table.
Bus Dev Func VendID DevID Class              Irq
00  01  00   1022   2080  Host Bridge
00  01  02   1022   2082  Chipset En/Decrypt 11
00  0C  00   1148   4320  Ethernet           11
00  0D  00   177D   0003  Network En/Decrypt 10
00  0F  00   1022   2090  ISA Bridge
00  0F  02   1022   2092  IDE Controller
00  0F  03   1022   2093  Audio              10
00  0F  04   1022   2094  Serial Bus         9
00  0F  05   1022   2095  Serial Bus         9
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(12)13) #0: Thu Aug 28 15:55:27 PDT 2008
Platform ASA5505
Use BREAK or ESC to interrupt boot.
Use SPACE to begin boot immediately.
  • Firewalling
Sorted it, just uploaded 8.4.7 via the rommon and set the image then it rebooted fine as 8.4.7 then I just did 9.1.3 the normal way.
ASA Upgrade to Version 9.1.3 Fails with "No Cfg structure found in downloaded image file" Error Message
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a0080c1e9f8.shtml
Value our effort and rate the assistance!
Do you need anything else, do you have any comments??
Na I as I mentioned I manged to fix it myself in the end.
1495
