ASA traffic issue
Hi, I'm working right now on a project implementing an ASA this way:
1. One interface of the ASA (Eth0/0) is connected to a Server (PHD Server) and the IPs are: 192.168.4.1/24 for the ASA-if Eth0/0 and 192.168.4.2/24 for the server.
2. Another interface of the ASA (Eth0/1) is connected to a Layer-2 Switch (VLAN 1) the switch can´t be manageable. The switch, at the other hand, connects with a Router interface (Gi0/0). The IP addresses are 172.17.21.250/24 for the ASA-if Eth0/1 and 172.17.21.1/24 for the Router-if Gi0/0.
3. Finally, the router connects to the last network through the Gi0/1 interface to a Switch (or for lab purposes to a Single PC). The IP addresses are: 172.17.20.50/24 for the Router-if Gi0/1 and 172.17.20.33 or .18  or 112 to the PC.
The PCs at the network 172.17.20.0/24 should have bidirectional communication with the Server at the network 192.168.4.0/24.
I configure all the interfaces at the ASA and at the Router and Switch.
The two ASA interfaces has the same security level (100) and the traffic between same security level interfaces is allowed.
All kind of traffic between the interfaces is permitted.
I created Static Routes at the ASA and at the Router to the remote networks knows each other.
I can ping the ASA (192.168.4.1) from the Server (192.168.4.2) and  vice versa
I can ping the Router (172.17.21.1) from the ASA (172.17.21.250) and vice versa
I can ping the Router (172.17.20.50) from the PC (172.17.20.33;18 or 112) and vice versa
I can ping the ASA (172.17.21.250) from the PC (172.17.20.33;18 or 112) and vice versa
but when I try
ping ASA (172.17.21.250) from server (192.168.4.2) it fails
ping Router (172.17.21.1) fromo server (192.168.4.2) it fails
ping ASA (192.168.4.1) from PC (172.17.20.33;18 or 112) it fails
ping server (192.168.4.2) form PC (172.17.20.33;18 or 112) it fails.
If I connect a PC with the IP: 172.17.21.1/24 at the ASA interface Eth0/1 (instead of the switch or router) all the pings pass from the Server to the PC and from the PC to the server.
I try also with tftp protocol, but the same happens.
I'm attanching the ASA configuration in case someone could see anything I cannot.
Re: ASA traffic issue
Jose,
     One of the tests you mention is pinging ASA interfaces that are not facing you... For example, from a Server on the DMZ, the *only* interface IP of the ASA you can ping is the DMZ interface, this is by design. From hosts off the inside interface (the router or the PC's), the *only* interface IP of the ASA they can ping on the ASA is the inside interface. Traffic passing through the box is another story....
I would suggest checking the routing table on the router. Make sure it points to the ASA (172.17.21.250) as its default gateway.
- Magnus
                  Inside .112 80------20.50Router 21.1-----.250 ASA 4.1----4.2Server
Saludos Jose !!!
Take a look at the information that I wrote.
Default behavior
Make sure default gateway is the ASA and that the router has the default gateway to the ASA or at
least a route telling him where 192.168.4.2 is
Default Behavior
Route on the Router to tell him where 4.2 is.
For the default behavior ones, the explanation is on the link below, you cannot ping an interface of the firewall
besides the one that you are facing.
"For security purposes the security appliance does not support far-end interface ping, that is pinging the IP address of the outside interface from the inside network"
Link
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/trouble.html#wp1059645
Hope it helps
Magnus!!! We are waiting for the New Podcast !!!!!!
Cheers
Mike
Mike
Thanks for the early answer.
I create an static route at the router ( ip route 192.168.4.0 255.255.255.0 172.17.21.250). At the other hand, I tried to do a TFTP transfer between the two PCs using TFTP32. And the transfer don´t even start. when I look at the ASDM debugging monitor there was no events related with the transfer, so I don't know if I have to turn some feature on or off.
Thanks.
Lets make it the easy way then.. Do the following
Packet-tracer input inside tcp 192.168.4.2 1025 172.17.20.112 80
This is going to tell me if the packet is allowed through the firewall coming from an inside host and going to the 192.168.4.2
Now to the same for the "return traffic"
packet-tracer input outside udp 172.17.20.112 1025 192.168.4.2 69
Will be waiting for the outputs..
Cheers.
Mike
Mike
Hi Maykol,
these are the prompts of the packet-tracer command
ASA-LAB# packet-tracer input LOCAL_PHD tcp 192.168.4.2 1025 172.17.20.33 http
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   RED-STMS        255.255.255.0   INTERNAL
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group ECI-TO-PETRO in interface LOCAL_PHD
access-list ECI-TO-PETRO extended permit ip any any
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 7, packet dispatched to next module
Result:
input-interface: LOCAL_PHD
input-status: up
input-line-status: up
output-interface: INTERNAL
output-status: up
output-line-status: up
Action: allow
ASA-LAB# packet-tracer input INTERNAL udp 172.17.20.33 1034 192.168.4.2 tftp
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.4.0     255.255.255.0   LOCAL_PHD
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group PETRO-TO-ECI in interface INTERNAL
access-list PETRO-TO-ECI extended permit ip any any
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: inspect-tftp
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect tftp
service-policy global_policy global
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 8, packet dispatched to next module
Result:
input-interface: INTERNAL
input-status: up
output-interface: LOCAL_PHD
output-status: up
Action: allow
thanks for your help.
245
