Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA - Transparent failover pair without STP possible?
I’m trying to see if it is possible to introduce two transparent ASA 5520s in an Active/Standby pair between 2 switches that don't currently run any form of STP.
Does anyone know if this is a supported configuration? I’m aware that if both ASA units thought that they were the master this could introduce a L2 loop but under normal operation would a failover succeed without creating a loop or is STP definitely required to achieve this set-up?
I'm trying to avoid having to use routed mode in this instance as re-numbering the address spaces would be quite difficult for this particular scenario.
Many thanks,
Andy
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hello Andy,
Exactly, while one unit is on standby mode it will not introduce any loop as it will not be forwarding any data.
That being said it's a supported scenario
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Andy,
Cheers,
Julio Carvajal
Community Member
Thanks Julio. I'm going to recommend the routed mode even though it's likely to cause some short-term pain. But it's good to know that transparent mode should be possible if that's not an option.
282
