ASA Transparent Mode Deployment Issue
  • Firewalling
VIP Green
Could you please be more specific as to what does not work.  How are you testing, from which IP to which IP is not working? Are you able to ping the switch from the ASA Firewall (not the transparent firewall)?
Please remember to rate and select a correct answer
-- Please remember to rate and select a correct answer
Case 1:
From management PC I can ping 10.10.10.10 & 10.10.10.11 but can not ping 10.10.10.1 or 10.10.20.1
Case 2:
Remove ips and directly connect the cable from the switch (gig0/8)to asa firewall (gig0/1) on top. Now I can ping 10.10.10.1 & 10.10.20.2 segment
VIP Green
Well seems you have found where the issue is yourself.  looks like there is a misconfiguration on the IPS.
Re: ASA Transparent Mode Deployment Issue
Could you please point me to the misconfiguration & how to resolve it?
Is the above setup supported?
VIP Green
Well you have it set to fail-open so it is a little strange that it is not allowing traffic through.  You could post the IPS config here and we can have a look and see if we can spot anything out of the ordinary.  Otherwise, you might also want to  post a question in the IPS/IDS section of the support forum.
IPS was set to fail open. I have tried this setup without any vlans and it seems to be working.
I strongly suspect multiple vlan in trnasparant mode will not work as ASA can not inspect vlan tagged packets. Correct me if I am wrong.
VIP Green
Ok after a little research I think I have found a solution for you ( I am leaving out the policy map configs):
firewall transparent
hostname ASA-IPS
interface GigabitEthernet0/0.20
vlan 20
nameif Outside2
bridge-group 2
security-level 0
interface GigabitEthernet0/0.10
vlan 10
nameif Outside1
bridge-group 1
security-level 0
interface GigabitEthernet0/1.22
vlan 22
nameif Inside2
bridge-group 2
security-level 100
interface GigabitEthernet0/1.11
vlan 11
nameif Inside1
bridge-group 1
security-level 100
interface BVI1
ip address 10.10.10.10 255.255.255.0
interface BVI2
ip address 10.10.20.10 255.255.255.0
access-list inside_acl extended permit ip any any
access-list outside_acl extended permit ip any any
access-group outside_acl in interface Outside1
access-group inside_acl in interface Inside1
access-group outside_acl in interface Outside2
access-group inside_acl in interface Inside2
Also make sure that you amend the VLANs on the switch to correspond to the VLANs on the Transparent ASA.
Thanks, I have tried this but not working.
But it means I need to create as many vlans & BVI's on ASA that exist in between?
VIP Green
From my understanding, yes.
606
