Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA - Troubleshooting Steps
What troubleshooting steps are required to see if the traffic is passing from a specific host from internal network to DMZ or from outside to inside...
Re: ASA - Troubleshooting Steps
A good step would be to go through the traffic logs.
However, if you dont want to go for logging/ syslog, these commands can be helpfull...
- "show access-list" >> to check the access-list hit count for that traffic.
- "show connection" >> to verify the entries in the connection table for your interesting traffic.
- "show xlate" >> to verify the entries in the NAT transalation table , whether correct NAT is configured or not.
Bronze
You can also use ASDM and filter the interesting traffic.
Silver
If you would capture traffic for VPN.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808c9a87.shtml
If you would capture traffic for specific source and destination:
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807c35e7.shtml
Configure above captures.
Dharmesh Purohit
298
