Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA Upgradation
HI All,
I have cisco asa 5520 firewall where currently I am running 8.2.5 IOS
I need to upgrade the same to 9.0
Can any one let me know what is the best procedure for doing the same
ASA Upgradation
You can upgrade directly to 9.0 but few important points to remember..
1. Version 8.3 and up - 5520 needs 2GB memory. Make sure ASA got enough memory.
2. There are nat statement syntax changed from 8.3 on. IOS will convert the config but make sure you read and understand all the syntax changes.
https://supportforums.cisco.com/docs/DOC-9129
3. Once you are ready, make sure you got backup of exsiting config (incase of roll back) and the procedure simply use a tftp server to copy IOS file to ASA flash and reboot.Check the below link.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008067e9f9.shtml
hth
MS
Community Member
ASA Upgradation
Thanks mvsheik
But can you let me know if I can use any tool for the same or software
Community Member
Re: ASA Upgradation
You need access to the dowload section at cisco.com to do this. Contact your reseller or cisco to do this.
Please rate as helpful, if that would be the case. Thanx
269
