Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Bronze
ASA upgrades and skipping versions
Aside from all of the normal 8.2 to 8.3 (and above) upgrade issues/concerns that are completely documented elsewhere, I'm wondering if anyone has seen the same issues I have had upgrading ASAs from 8.2(x) to anything above 8.4(x)?
The problems below seemed to caused by skipping versions or at least I thought these particular issues were avoided when I did not skip upgrade versions
adding unidirectional nat
leaving off nat route lookup
adding nat (inside,any)
Is there a way to avoid these issues when skipping upgrade versions?
Appeciate your input.
Thanks.
Everyone's tags (2)
157
