Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA V-Lan Conf
I have setup a new Cisco L3 Switch and create three different V-Lan.
1) V-lan 100 192.168.12.0/24 f0
2) V-lan 200 192.168.13.0/24 f1
3) V-lan 300 192.168.14.0/24 f2
F3 switch port is directly connected with ASA 5505 FW.
ASA Inside IP 192.168.10.2
Switch F3 IP 192.168.10.1
Now I want that all Vlan traffic request for internet to be go through ASA. Please suggest what type of config I will have to do?
3 ACCEPTED SOLUTIONS
Re: ASA V-Lan Conf
AS reference will try to exmplain a bit more so that you can know the obtions in future.
You cannot delete the management default VLAN1 off the switch or any switch as it is a default embeded vlan in the switch code, but you can choose any other vlan for management and leave VLAN1 alone with no IP adddress and be able to telnet to the switch from any other SVI interface , it is just simply for management. The VLAN1 Association on the switch is local to the switch and not the firewall.
If you had created the VLANS on the ASA for example
interface Ethernet0/1.100
vlan 100
nameif inside1
security-level 100
ip address 192.168.10.1 255.255.255.0
interface Ethernet0/1.101
vlan 101
nameif inside2
security-level 101
ip address 192.168.11.1 255.255.255.0
same-security-traffic permit inter-interface
then in the switch the trunk must be configured and associate the ASA VLAN# to the switch L2 VLAN# as bellow.
switch: Layer 2 vlans
vlan database
vlan 100 name inside1
vlan 101 name inside2
interface fastethernet0/48
Description Connection to ASA_Inside_Ethernet1
switchport mode trunk
switchport trunk allow vlan 100,101 etc..
In original replies example the fe0/48 defaults to vlan1 anyways and switchport access vlan 1 command is not required Im just pickie about it and place it when there are many vlans configured and want to know who is who on the switch ports, you are correct in saying master port, although I have not heard that tearm in switches but I think you meant by master port the primary physical
connection to the firewall inside interface.
Re: ASA V-Lan Conf
No because internal routing is enabled on the switch, they will talk to each other fine.
Re: ASA V-Lan Conf
Yes, ACLs will be required in the L3 switch if you want to control traffic between the subnets.
Silver
Re: ASA V-Lan Conf
No shut the actual interface and create a sub-interface for each vlan. Physical can't have a vlan so you'll need 3 subs. Configure sub-interfaces the same way you would a physical interface. Setup your L3 switch interface as a 802.1q trunk port.
interface physical_interface.subinterface
vlan vlan-id
EX:
interface g0/1.10
vlan 10
Chad
Please rate if helpful.
Re: ASA V-Lan Conf
hi Chad
ur idea right 100%
but he said he is useing L# switch and as he mentioned ha has given an ip address to the switch interface so this interface not trunk and layer two port any more
and upon ur config he will use his switch as L2 switch only
while he can benifit from his layer three switch and make all the oruting in the L3 switch and the full config as mention in my post to him
Unless he wants the comunication between vlans be through the firewall in this case he dose not need to make the routing on the L3 switch
thank you
Re: ASA V-Lan Conf
the easy way is as follow:
first inter the following command on the switch to enable routing
ip routing
then
creat thre SVIs on the switch
like
interface vlan 100
ip address 192.168.12.1 255.255.255.0
no shut
interface vlan 200
ip address 192.168.13.1 255.255.255.0
no shut
interface vlan 300
ip address 192.168.14.1 255.255.255.0
no shut
then creat a default route point to the ASA inside interface
on the switch
ip route 0.0.0.0 0.0.0.0 192.168.10.2
make the switchport connected to the asa as a routed port
for eaxmle
interfaces fa0/3
no switchport
no shut
now on the ASA creat three static routes each one point to one of ur vlans and going throu the switch interface
on the asa:
route inside 192.168.12.0 255.255.255.0 192.168.10.1
route inside 192.168.13.0 255.255.255.0 192.168.10.1
route inside 192.168.14.0 255.255.255.0 192.168.10.1
and for any clients connected to the switch
if u copnnect client to vlan 100
this client default gateway must be vlan 100 interface that we created above
and the same idea for each vlan
and good luck
please, if helpful rate
Re: ASA V-Lan Conf
Marwan's suggestion is the easiest way to do it which is actually creating SVI interfaces in your L3 switch.. you could do ospf adjacency between asa inside and l3 switch but Marvan's example is good way to go with.
Additionally you will need to add those SVI subnets in asa to PAT them using global outboung interface for internet traffic.
e.i.
global (outside) 1 interface
nat (inside) 1 192.168.12.0 255.255.255.0
nat (inside) 1 192.168.13.0 255.255.255.0
nat (inside) 1 192.168.14.0 255.255.255.0
Rgds
Jorge
Re: ASA V-Lan Conf
thanks jorge especially for nating
because i got busy arranging the routing for him
sure the nating must be done for all internal vlans subnets to intgrate with static route that we have added to the asa
i mean the way out and bak end to end
Community Member
Re: ASA V-Lan Conf
Thanks for all suggestions, but as I know when the all V-Lan traffic goes to other device by using a single port on switch then trunk port must be configured. In this above scenario, Is it not required a configured Trunk Port?
Re: ASA V-Lan Conf
In above scenario trunking is not required because you are not creating the VLANS in the firewall. When you do 802.1q subinterfaces in ASA then you need to extend those vlans to the switch via trunk. But because you are doing inter vlan routing withing the L3 switch you just simply need the example provided by Marwan.
Rgds
Jorge
Community Member
Re: ASA V-Lan Conf
Well the ASA is setup with default configuration and the inside interface is also associated with V-lan1. Does it requires to change anything on ASA Inside Interface which will be connect with Switch port.
If I use inter v-lan routing on L3 Switch then what commands I need to execute. Thanks
Re: ASA V-Lan Conf
lets take ASA inside interface subnet 192.168.10.0/24
you can do as follows.
Switch has default VLAN1 which is management vlan. Configure management vlan in same network as your ASA inside subnet
example on switch:
interface vlan1
ip address 192.168.10.3 255.255.255.0
no shut
then connect ASA inside physical port on a switchport on the switch.
description ASA_Inside_Interface
speed 100
duplex full
no shut
And thats it, complete the Marvwan's example, doing default route pointing to ASA inside interface IP address.
For your hosts on 12,13,14 Default gateway will be SVI interface IP address, and for internet access follow the NAT (inside) 1 example above..
Let us know if you need a more complete script but you should be good to go..
[edit]
For inter-vlan routing configuration create the svi on the switch as Marwan provided example, for the SVI interfaces you create for them to be up/up you must connect a host on the allocated switchport and place the switch port in the correct SVI vlan.
example
interface vlan 100
no shut
interface fastethernet0/1
Description WIndowsXP_PC1
switchport access vlan 100
speed 100
duplex full
no shut
Rgds
Jorge
Community Member
Re: ASA V-Lan Conf
If I delete V-Lan 1 which is associated with ASA Inside Interface then is it required the following commands on Switch Management Interface.
speed 100
duplex full
no shut
Community Member
Re: ASA V-Lan Conf
As I understand without V-lan configured on ASA Inside Interface and the connected port of switch will work like as a Master Port.
Re: ASA V-Lan Conf
vlan 100
nameif inside1
security-level 100
vlan 101
nameif inside2
security-level 101
vlan database
Community Member
Re: ASA V-Lan Conf
Valuable!!!! I appreciate. Guys please don't mind as I am bit confused in the V-Lans configuration that's why I am putting lot of queries and hope all confusion part will be wash out by your support.
Can you please tell me now how can I do inter-VLan routing into L3 Switch. Please show an example if possible. Thnaks
Community Member
Re: ASA V-Lan Conf
waiting
Re: ASA V-Lan Conf
Assuming you have already configure basic ASA inside interface with 192.168.10.2/24
1-Start with Layer 2 vlans on switch, and use VLAN1 for management on same segment as ASA inside interface
2-Create L3 SVI interfaces for earch Layer 2 VLAN you created
3-Enable routing on the switch
4-Configure ASA static routes to talk to 12,13,14 subnets via 192.168.10.1
5-Configure ASA for NATing your inside hosts in L3 switch for internet access
6-COnfigure ASA with same-security-traffic permit intra-interface
7-ALLOw any subnet from behind ASA access to ASA for telnet and/or http for management
vlan database
vlan 100 name 192.168.12.0/24
vlan 101 name 192.168.13.0/24
vlan 102 name 192.168.14.0/24
exit
verify vlans " show vlan"
Now Create SVIs
interface vlan 100
Description 12.0/24 subnet
IP address 192.168.12.1 255.255.255.0
no shutdown
interface vlan 101
Description 13.0/24 subnet
IP address 192.168.13.1 255.255.255.0
no shutdown
interface vlan 102
Description 14.0/24 subnet
IP address 192.168.14.1 255.255.255.0
no shutdown
Management Vlan1 in switch which also servers as L3 connection to ASA
interface vlan1
Description Management
no shutdown
Enable routing in switch and configure default route
ip routing
Allocate switch port Fe0/48 to connect to ASA inside interface
Description Connection to ASA_Ethernet1
speed 100
duplex full
no shutdown
test pinging from switch to asa inside interface - if ok proceed ..
ASA side configuration
http server enable
http 192.168.12.0 255.255.255.0 inside
http 192.168.13.0 255.255.255.0 inside
http 192.168.14.0 255.255.255.0 inside
telnet 192.168.12.0 255.255.255.0 inside
telnet 192.168.13.0 255.255.255.0 inside
telnet 192.168.14.0 255.255.255.0 inside
route 0.0.0.0 0.0.0.0 ISP_NetHop_Router_IP 1
Now for real test, you need to place in switches PC hosts for the SVI interfaces to come up
Rememner that PCs default gateway will be the IP of the SVI interfaces.
Interface fastethernet0/1
Description PC1_192.168.12.40/24
no shutdown
Interface fastethernet0/2
Description PC1_192.168.13.40/24
switchport access vlan 101
no shutdown
from PC in subnet 100 ping its default gateway at 192.168.12.1
From PC in subnet 101 ping its default gatewat at 192.168.13.1
From PC in subnet 100 ping PC in subnet 101
From PC in subnet 100 ping asa Inside interface at 192.168.10.2
from PCs connect to internet
Did I missed anything?
Community Member
Re: ASA V-Lan Conf
Hi, Thanks for your reply.
What is the use of this command.."same-security-traffic permit intra-interface" As I understand this command is to enable the V-lan's communication which is configured on Switch.
Here, I want to configure the Inter-V-Lan routing on L3 switch instead of ASA. Is it required and static commands or routing protocols like RIP, OSPF and etc. Please advice.
Re: ASA V-Lan Conf
if you place any other hosts on 192.168.10.0/24 subnet beside the switch vlan1 192.168.10.1 and asa inside interface 192.168.10.2 you need this command in asa for traffic from 12,13,14 subnets to talk to hosts on the 10 subnet go out the same interface it came. Omit the command otherwise!
same-security-traffic permit intra-interface.
Community Member
Re: ASA V-Lan Conf
And what about V-Lan communication? How will it be configured on L3 Switch?
Re: ASA V-Lan Conf
Inter VLAN communication will be handle by the L3 switch and its routing function within.
Community Member
Re: ASA V-Lan Conf
Is it not required any configuration on L3 Switch to talk with each other among V-lans?
Re: ASA V-Lan Conf
Community Member
Re: ASA V-Lan Conf
If I want to allow only one V-lan communicate with other V-lans then is it required access-list?
Community Member
Re: ASA V-Lan Conf
Last Question :- Can you please explain about following command in more details.
Re: ASA V-Lan Conf
This command is handly for many purposes in the ASA, one purpose is the one I previously mentioned, another purpose is full RA tunnels and internet access via your ASA firewall go out the same interface the RA connections come in. It does not hurt to have this command already configured in the firewa..
Re: ASA V-Lan Conf
Community Member
Re: ASA V-Lan Conf
Re: ASA V-Lan Conf
Here is a good visual example of same-security-traffic permit intra-interface
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a0080734db7.shtml#t3
Community Member
Re: ASA V-Lan Conf
Thanks everyone for your prompt response specially Jorgemcse. Thank you so much.. Have a nice day :)
Re: ASA V-Lan Conf
i guess from the rating the config i have given didnt work with u ?
anyway
hope i was helpful
188
