ASA with blocked access, status LED and active in amber
Hi friend,
I have CISCO ASA5510-CSC20-K9, this is used for education, a day dawned blocked with status LED and active in amber,
Mauricio
1 ACCEPTED SOLUTION
Gold
Re: ASA with blocked access, status LED and active in amber
Hi Mauricio,
An amber status LED indicates that the unit failed its power-on diagnostics. Do you see any output on the console port when you power the unit up? I would suggest opening a TAC case so this can be investigated and replaced if it is found to be a hardware failure.
-Mike
Gold
Hi Mauricio,
-Mike
gracias por responder ya lo envie a garantia
938
