ASA with Web Filter
I'm tring to install an ASA firewall on my system, but I also want to use my web filtering software that functions as a proxy on another server. Is there a way i can setup my ASA to route traffic to the web filter? Also will the ASA be able to pass windows authentication so my filter can still be based on username?
Re: ASA with Web Filter
Hi .. as far as I know the ASA like the PIX only supports 2 URL filters vendors Websense and
Secure Computing SmartFilter (formerly N2H2). having said that .. you could perhaps try using your web filter but of course Cisco will not provide any support .. assuming you are able to get this working. please refer to the below link for information.
http://cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a0080637340.html
I hope it helps .. please rate it if it does
That was helpful thank you, unfortunately i don't use WebSense or Secure Computing SmartFilter so i don't know how to set this up. Would it be possible to have the ASA send outbound requests to a proxy?
193
