Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA-X Monitor interface via Hello Packet ?
Dear Cisco,
I add a command to monitor ASA5515-X Firewall Outside interface. I show the monitor interface and see the log that the Outside passed the tracking. Cisco configuration Guide says that Hello packet should be sent so as to track the interfaces.
My connection scenario is listed below.
1) A primary switch is connected to Primary ASA's outside interface GE0/0, the interface is up
2) A Backup switch is connected to Backup ASA's outside interface GE0/0, the interface is up
3) In the beginning, the two switch is connected.
4) After the 2x firewall syn, Disconnect the connection between primary and backup switch
5) Hello packet could not be delivered via the Outside Interface anymore.
6) When I "show Monitor-interface, the ASA shows that Outside interface is normal, and thus does not fail over. What goes wrong ?
As I am working for a SI, and my manager says raise Cisco TECH ticket as few as possible. I want to confirm if this is abnormal before I strongly request to open a TECH case.
ASA5515X   Version 9.1(1)
Thanks.
Peter
1 REPLY
Hi,So you mean to say that
So you mean to say that the Physical ports on both the ASA device i.e outside interface cannot communicate with each other but still they show NORMAL under the fail-over monitoring ?
Thanks and Regards,
Vibhor Amrodia
109
