ASA5505 8.2(3) has trouble browsing websites - PMTU-D errors
This one has been puzzling me a bit.
We have been having continuous MTU issue with suring certain website. Our MTU is set to 1454 on a PPoE connection (which works with a laptop directly connected) and when I try to browse certain website (like www.cisco.com) I get the following errors on the sys log
PMTU-D packet 1420 bytes greater than effective mtu 1050, dest_addr=[WANIP], src_addr=[Random website], prot=tcp
PMTU-D packet 1300 bytes greater than effective mtu 1050....
I know that PMTU relies on ICMP which I have allowed and I have also made sure that the default inspection has ICMP and ICMP Error ticked in ASDM.
I know alot of people have these issues with site2site VPN (my site to site vpns are fine its just external website browsing)
I am at a bit of a loss and any help would really be appreciated.
Cisco also has an article about this but with my version of ASA "exceed-mss allow" seems to be a default setting.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804c8b9f.shtml
*attached current config*
Cheers!
Re: ASA5505 8.2(2) has trouble browsing websites - PMTU-D errors
sorry quick update I am running 8.2(3) not (2)
Some layer 3 device in the path has a lower MTU configured. You can try to change the MTU on the firewall and see if this helps. This will increase the nubmer of packets.
conf t
mtu outside 1050
-KS
Thanks for your response.
I tried to drop the MTU down as low as that but still no success. I can still see the PMTU-D errors and I started to get ICMP drops
4    Dec 01 2010    07:55:29                        No matching connection for ICMP error message: icmp src outside:ExternalIP dst inside:WANIP (type 11, code 1) on outside interface.  Original IP payload: udp src WANIP dst ExternalIP
The ASA is directly connected to a ONU for internet access and its using PPoE. The static IP is assigned automatically.
On the ASDM when I go to Firewall -> Advanced -> Fragment I see the below.
Interface: inside
    Size: 200, Chain: 24, Timeout: 5, Reassembly: virtual
    Queue: 0, Assembled: 0, Fail: 1, Overflow: 0
Interface: outside
    Queue: 0, Assembled: 282, Fail: 13235, Overflow: 0
Outside and interface are both set to
Size 200
Chain Length 24
Timeout 5
Not sure if that helps.
That sure helps.
You can add the following and see if it helps.
hostname(config)# fragment size 2000 outside
1761
