ASA5505 and Asterisk remote Softphone doesn´t work
Hi experts,
I have a problem with mi telephony server. My network topology is very simple. I have an ASA5505 connected to Internet throught an ISP. Behind ASA5505 I have a ToIP Server that operate well inside LAN network. However, when I try to register two or more extensions (Softphones) from Internet, Softphones some times it registers sucessfully, but some times doesn´t work.
The other hand, when softphones outside from LAN get register sucessfully in Asterisk server, is not possible that one of this calling the other one, and Asterisk server detects them as "UNREACHABLE". I don´t know if the problem are all commands of traffic inspect or if the problem is referenced to a particular UC proxy License.
These are configuration lines:
object-group service elastix-ports
service-object udp eq sip
service-object udp gt 10000
service-object udp eq 4569
service-object tcp eq 1222
service-object tcp eq https
service-object tcp eq 4445
service-object tcp eq ssh
service-object icmp
access-list outside_in extended permit object-group elastix-ports object-group elastix-connections host Asterisk_IP_Public
access-list inside_in extended permit ip any any
access-group inside_in in interface inside
access-group outside_in in interface outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
As you see, ACLs are not a problem. Someone has any idea?.
I'll be very grateful
Regards.
DT.
1 REPLY
Hi Darwin,
The first step would be to get debugging (7) level syslogs, 'debug sip' output, and bi-directional packet captures on both sides of the ASA when a problem phone is trying to register. If the problem is not apparent from the above output, I would recommend opening a TAC case to have it investigated further.
-Mike
444
