ASA5505 ASDM WON'T LAUNCH
I am at my witts end with this one and can't seem to find anything that matches my situtation. So I have an ASA5505 that I am trying to get the ASDM running on. I have done this before on other firewalls with no issue. Everytime I go to the url https://192.168.1.1 I get the prompt to accept the certificate which I do, then it just goes blank and the page freezes. If I try to launch it straight from the ASDM launcher it also just freezes. I have double checked my ssl encryption and made sure it has rc4-sha1 aes128-sha1 aes256-sha1 3des-sha1. I am using asdm-714.bin image and have tried getting it run on the asa 8.2.5, 8.4.7 and 9.1.3 code and get the same results with each version of code I put on this device. I have also tried multiple computers, and both computer connect to my other firewalls just fine via url to lauch asdm or asdm launcher so I know it isn't a java issue with them. Is there something I am missing?? I have tried accessing the url using Safari, Firefox, Chrome and IE, all with the same results, accept the cert and it just hangs there and never displays the asdm launch page. Please Help!
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: ASA5505 ASDM WON'T LAUNCH
From customer:
Also I have tried power cycling the ASA, using a diffrent asdm image file, the image file "asdm-714.bin"
So it's a bug. I mean we clearly see the problem with the SSL Crypto Hardware Accelerator
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
ASA5505 ASDM Freezing
More information, I have currently put 8.2.5 code back on my 5505, and have "asdm image disk0:/asdm-714.bin" go to the url accept the cert, and it just freezes.
Share:
Show run http
show run aaa
show run asdm
Can you also enable
debug http 255
and then connect
Jcarvaja
ciscoasa# show run all http
http server enable 443
http 192.168.1.0 255.255.255.0 inside
show run all ssl
ssl server-version any
ssl client-version any
ssl encryption rc4-sha1 aes128-sha1 aes256-sha1 3des-sha1
ciscoasa# show ssl
Accept connections using SSLv2, SSLv3 or TLSv1 and negotiate to SSLv3 or TLSv1
Start connections using SSLv3 and negotiate to SSLv3 or TLSv1
Enabled cipher order: rc4-sha1 aes128-sha1 aes256-sha1 3des-sha1
Disabled ciphers: des-sha1 rc4-md5 null-sha1
No SSL trust-points configured
Certificate authentication is not enabled
ciscoasa# show run all aaa
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
aaa proxy-limit 16
no aaa authentication secure-http-client
no aaa local authentication attempts max-fail
no aaa authorization exec authentication-server
ciscoasa# show run all asdm
no asdm history enable
ciscoasa# debug http 255
debug http enabled at level 255.
ciscoasa# HTTP: Periodic admin session check  (idle-timeout = 1200, session-timeout = 0)
Also I have tried power cycling the ASA, using a diffrent asdm image file, the image file "asdm-714.bin" I got straight from the cisco web site and I have put that image file on another ASA and it worked fine. I am so lost on this one, the debug isn't showing anything when I try to connect, it just keeps giving the;
Any ASA Ninja's out there have any idea what I should try next?
do
capture capin interface inside match tcp any host x.x.x.x eq 443 (where x.x.x.x is the ASA inside interface)
capture asp type asp-drop all circular-buffer
afterwards try to connect and provide
show cap capin
show cap asp | include x.x.x.x
Jcarvaja
ciscoasa(config)# show capture
capture capin type raw-data interface inside [Capturing - 0 bytes]
  match tcp any host 192.168.1.1 eq https
capture asp type asp-drop all circular-buffer [Capturing - 1066 bytes]
ciscoasa# show cap asp | include 192.168.1.1
   1: 09:20:30.891280 802.1Q vlan#10 P0 192.168.1.102.58504 > 192.168.1.1.80: S 3815319795:3815319795(0) win 65535 Drop-reason: (acl-drop) Flow is denied by configured rule
   2: 09:20:31.916898 802.1Q vlan#10 P0 192.168.1.102.58504 > 192.168.1.1.80: S 3815319795:3815319795(0) win 65535
   3: 09:20:33.024611 802.1Q vlan#10 P0 192.168.1.102.58504 > 192.168.1.1.80: S 3815319795:3815319795(0) win 65535 Drop-reason: (acl-drop) Flow is denied by configured rule
   4: 09:20:34.032224 802.1Q vlan#10 P0 192.168.1.102.58504 > 192.168.1.1.80: S 3815319795:3815319795(0) win 65535 Drop-reason: (acl-drop) Flow is denied by configured rule
   5: 09:20:35.138573 802.1Q vlan#10 P0 192.168.1.102.58504 > 192.168.1.1.80: S 3815319795:3815319795(0) win 65535 Drop-reason: (acl-drop) Flow is denied by configured rule
   6: 09:20:35.186071 802.1Q vlan#10 P0 192.168.1.102.17500 > 192.168.1.255.17500:  udp 122 Drop-reason: (acl-drop) Flow is denied by configured rule
   7: 09:20:36.248735 802.1Q vlan#10 P0 192.168.1.102.58504 > 192.168.1.1.80: S 3815319795:3815319795(0) win 65535 Drop-reason: (acl-drop) Flow is denied by configured rule
   8: 09:20:38.264985 802.1Q vlan#10 P0 192.168.1.102.58504 > 192.168.1.1.80: S 3815319795:3815319795(0) win 65535 Drop-reason: (acl-drop) Flow is denied by configured rule
   9: 09:20:42.283783 802.1Q vlan#10 P0 192.168.1.102.58504 > 192.168.1.1.80: S 3815319795:3815319795(0) win 65535 Drop-reason: (acl-drop) Flow is denied by configured rule
  10: 09:20:50.287659 802.1Q vlan#10 P0 192.168.1.102.58504 > 192.168.1.1.80: S 3815319795:3815319795(0) win 65535 Drop-reason: (acl-drop) Flow is denied by configured rule
  11: 09:21:05.202916 802.1Q vlan#10 P0 192.168.1.102.17500 > 192.168.1.255.17500:  udp 122 Drop-reason: (acl-drop) Flow is denied by configured rule
  12: 09:21:06.341260 802.1Q vlan#10 P0 192.168.1.102.58504 > 192.168.1.1.80: S 3815319795:3815319795(0) win 65535 Drop-reason: (acl-drop) Flow is denied by configured rule
  13: 09:21:35.221820 802.1Q vlan#10 P0 192.168.1.102.17500 > 192.168.1.255.17500:  udp 122
  14: 09:22:05.246065 802.1Q vlan#10 P0 192.168.1.102.17500 > 192.168.1.255.17500:  udp 122 Drop-reason: (acl-drop) Flow is denied by configured rule
  15: 09:22:35.270432 802.1Q vlan#10 P0 192.168.1.102.17500 > 192.168.1.255.17500:  udp 122
huh, there is some acl rule dropping it if i am reading this right, but i don't even have any ACL's configured on this ASA. I did a "wr erease" have have really only done the config to the point so I can't access the asdm.
Check my ARP, Connectivity post and provide results
Jcarvaja
Re: ASA5505 ASDM Freezing
Hello Brett,
Can you ping the Client PC from the ASA?
Do you see an ARP entry??
It seems like the packets are not even reaching the ASA bud.
Can you try from a different machine
Jcarvaja
I can ping the asa from my computer, and I have tried from two different computers now
Bretts-MBP:~ berickson$ ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1): 56 data bytes
64 bytes from 192.168.1.1: icmp_seq=0 ttl=255 time=1.075 ms
64 bytes from 192.168.1.1: icmp_seq=1 ttl=255 time=0.709 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=255 time=0.728 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=255 time=0.708 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=255 time=0.825 ms
^C
--- 192.168.1.1 ping statistics ---
5 packets transmitted, 5 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.708/0.809/1.075/0.140 ms
What java version do you have on the PCs?
Jcarvaja
ciscoasa# show arp
        inside 192.168.1.102 5855.ca22.ffd2 96
on the mac i am currently using 7 update 35 and I can connect to two other asa's with no issue. I guess I can't ssh to it either, i just tried that for kicks.
JK, I can ssh, I forgot to add my "ssh 192.168.1.0 255.255.255.0 inside" ssh works fine now, just can't access the asdm
Here is the running config, am I missing somethine? I have checked it so many times.
ciscoasa# show run
: Saved
ASA Version 8.2(5)
hostname ciscoasa
domain-name test.local
enable password *removed* encrypted
passwd *removed* encrypted
names
interface Ethernet0/0
switchport access vlan 10
interface Ethernet0/1
shutdown
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
interface Vlan1
shutdown
no nameif
no security-level
no ip address
interface Vlan10
nameif inside
security-level 100
ftp mode passive
dns server-group DefaultDNS
pager lines 24
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.100-192.168.1.150 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username berickson password *removed* encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:28857584cf7b907dec6680534afadc01
: end
Hello
is 102 the internal PC?
Can you do a show flash?
Jcarvaja
yes 102 is my computer, and I can ping 192.168.1.102 (my computer) from the asa
ciscoasa(config)# show flash:
--#--  --length--  -----date/time------  path
    3  4096        Aug 23 2013 19:26:26  log
   12  4096        Dec 05 2013 14:42:34  crypto_archive
  116  410532      Dec 05 2013 14:42:10  crypto_archive/crypto_eng0_arch_1.bin
  117  410532      Dec 05 2013 14:42:34  crypto_archive/crypto_eng0_arch_2.bin
   13  4096        Aug 23 2013 19:27:06  coredumpinfo
   14  59          Dec 02 2013 10:09:30  coredumpinfo/coredump.cfg
  102  4792138     Jun 16 2011 15:52:06  anyconnect-win-2.5.3041-k9.pkg
  103  15390720    May 25 2011 19:14:58  asa825-k8.bin
  104  26772780    Apr 20 2011 16:26:46  csd_3.6.181-k9.pkg
  105  418765      Sep 28 2009 12:00:44  sslclient-win-1.1.4.179.pkg
  106  17790720    Dec 02 2013 09:50:44  asdm-711-52.bin
  107  22658960    Dec 05 2013 15:33:12  asdm-714.bin
  108  0           Dec 02 2013 10:09:30  nat_ident_migrate
  109  2768        Dec 02 2013 10:09:30  8_2_5_0_startup_cfg.sav
  110  1138        Dec 02 2013 10:09:30  upgrade_startup_errors_201312021009.log
  112  27408384    Dec 02 2013 11:06:02  asa903-k8.bin
  113  26984448    Dec 02 2013 11:06:42  asa913-k8.bin
  114  24809472    Dec 02 2013 11:46:20  asa847-k8.bin
256503808 bytes total (88137728 bytes free)
I just don't get it, why would it hit the ASA from my web browser then ask me if I want to accept the certificate and then once I accept it then it just does nothing?
Ok I have been trying to connect and checking the capture you had me setup, I saw this one.
79: 09:45:50.837481 802.1Q vlan#10 P0 192.168.1.102.58824 > 192.168.1.1.443: R 86402545:86402545(0) win 0 Drop-reason: (tcp-rstfin-ooo) TCP RST/FIN out of order
I can't see how it would be java related, I can't even display the web page that would then launch the java application.
Here is the version info if this helps anyone come up with any ideas, i am so at a loss right now...
ciscoasa# show version
Cisco Adaptive Security Appliance Software Version 8.2(5)
Device Manager Version 7.1(4)
Compiled on Fri 20-May-11 16:00 by builders
System image file is "disk0:/asa825-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 4 mins 2 secs
Hardware:   ASA5505, 256 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.05
0: Int: Internal-Data0/0    : address is 0021.5595.8321, irq 11
1: Ext: Ethernet0/0         : address is 0021.5595.8319, irq 255
2: Ext: Ethernet0/1         : address is 0021.5595.831a, irq 255
3: Ext: Ethernet0/2         : address is 0021.5595.831b, irq 255
4: Ext: Ethernet0/3         : address is 0021.5595.831c, irq 255
5: Ext: Ethernet0/4         : address is 0021.5595.831d, irq 255
6: Ext: Ethernet0/5         : address is 0021.5595.831e, irq 255
7: Ext: Ethernet0/6         : address is 0021.5595.831f, irq 255
8: Ext: Ethernet0/7         : address is 0021.5595.8320, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Licensed features for this platform:
Maximum Physical Interfaces    : 8
VLANs                          : 20, DMZ Unrestricted
Inside Hosts                   : Unlimited
Failover                       : Active/Standby
VPN-DES                        : Enabled
VPN-3DES-AES                   : Enabled
SSL VPN Peers                  : 2
Total VPN Peers                : 25
Dual ISPs                      : Enabled
VLAN Trunk Ports               : 8
Shared License                 : Disabled
AnyConnect for Mobile          : Disabled
AnyConnect for Cisco VPN Phone : Disabled
AnyConnect Essentials          : Disabled
Advanced Endpoint Assessment   : Disabled
UC Phone Proxy Sessions        : 2
Total UC Proxy Sessions        : 2
Botnet Traffic Filter          : Disabled
This platform has an ASA 5505 Security Plus license.
Serial Number: *removed*
Running Activation Key: *removed*
Configuration register is 0x1
Configuration has not been modified since last system restart.
I even just tried reformating my flash to see if that helped, I only put the asa825-k8.bin and asdm-714.bin back on it.
ciscoasa# show flash:
   41  22658960    Dec 05 2013 03:45:44  asdm-714.bin
   42  15390720    Dec 05 2013 03:46:22  asa825-k8.bin
    2  4096        Dec 05 2013 03:56:11  log
    9  4096        Dec 05 2013 03:56:37  crypto_archive
   50  4096        Dec 05 2013 03:56:47  coredumpinfo
   51  43          Dec 05 2013 03:56:47  coredumpinfo/coredump.cfg
255320064 bytes total (216899584 bytes free)
Still no luck, and double verified that my asdm-714.bin works on a different ASA running 8.2.5 code as well.
Julio do you have any other advice? Could it possibly be hardware related?
Yeah it does not make any sense.
What happens if you plugin a computer directly to the ASA and attempt to connect?
You have no idea how many Bugs are related to the Java version bud.
I am sorry if I am going around bud have you rebooted the box?? If yes then do the following:
Let's restart the HTTPS daemon
clear configure HTTP
clear configure asdm
Create your own permanent self-signed certificate and then
Configure HTTP/ASDM again,
Jcarvaja
Computer is plugged directly into the ASA, quick question, when you say to create my own permanent self-signed cert are you just refering to the "crypto key generate rsa" command or is there more to it?
Hello Brett,
Wow this is getting crazy man,
Is there a way that you could downgrade to Java v6?
I know bud. I know.. This works with other firewalls but you have no idea how many times the solution of a ticket was that.
Hope you try it
Jcarvaja
Yes, I am currently using Java 7 update 25, as it was the recommended on ciscos web page. But I will down grade to java 6 and let you know how it goes.
ha, this will be the death of me, I installed java 6 update 45, try to hit the web page in IE, accept the cert and then.....
NOTHING!!
I really do appreciate your help, I thought I was just missing something, that is why I was wondering if there was any type of hardware issue that could be causeing this as nothing I have tried has seemed to work.
4976
