08-07-2013 01:40 PM - edited 03-11-2019 07:23 PM
10.15.50.0/24 <---> 10.15.50.254 (inside / ASA5505 \ outside) 10.60.15.253 <---> 10.60.15.254 <--- (cloud) ---> (eventual destination 10.15.60.0/24)
Goal:
10.15.50.0/24 traffic will communicate with 10.15.60.0/24 while block all other. Current config is any/any for troubleshooting.
Example:
10.15.50.249 pings 10.60.15.253 (inside of ASA) and fails. Running it thru ASDM Packet Tracer shows the Outside ASA interface blocking but I have any/any on that interface.
Question:
What am I doing wrong?
: Saved
ASA Version 8.2(5)
hostname SJ-HostB-ASA
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 10.15.50.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 10.60.15.253 255.255.255.252
boot system disk0:/asa825-k8.bin
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list outside_access_in extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-645.bin
no asdm history enable
arp timeout 14400
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 10.60.15.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication serial console LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
aaa authorization command LOCAL
aaa authorization exec LOCAL
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no sysopt connection permit-vpn
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp policy 1
authentication pre-share
encryption aes-256
hash sha
group 1
lifetime 86400
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 30
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 30
console timeout 30
management-access inside
threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ntp server 10.15.50.243 source inside
webvpn
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http
destination address email
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
: end
08-07-2013 05:46 PM
You can only PING / ICMP an ASA interface from behind that same interface.
So users behind "inside" can PING / ICMP the "inside" interface IP address and users behind "outside" can PING / ICMP the "outside" interface IP address. Users can't PING / ICMP the remote interface from their perspective. The only exception is when users are coming through VPN connection and you use the "management-access
You seem to be simulating an ICMP send from behind "inside" to the "outside" interface IP address if what you say is true.
So attempt the Packet Tracer using some remote network IP address in the 10.15.60.0/24 network.
You dont seem to have "nat-control" enabled so all traffic should be able to pass through the ASA without translation. So NAT shouldnt be a problem.
You can also add the following configurations
inspect icmp
inspect icmp error
- Jouni
08-08-2013 01:56 PM
This ASA is being used to access another ASA across a customer's closed network. Unfortunately the had a missing route in the first hop router that was preventing a ping from 10.15.50.0/24 to 10.60.15.254. One the missing route was added we had connectivity to the other end (an ASA).
