ASA5505 -- Dual Wan -- Port Forwarding
I'm hoping to get some recommendations on how to configure this setup.... I have an ASA5505 with dual wan failover, FiOS (eth0) & Cable (eth1).  I'm wondering how to configure the port forwarding for all my devices so it doesn't matter what external interface the traffic is coming from.  For example, I need web traffic on port 80 forwarded to 192.168.1.150 regardless of whether it is coming through eth0 or eth1.  Is this possible?  If so, could you possibly provide an example of what the rules would look like?
Thanks!
Can you add your config. Thanks
Please remember to rate useful posts, by clicking on the stars below.
Hello Mat,
It is possible, just need to do the same thing for the other interface and that's it.
Example if you have static (inside,outside) x.x.x.x y.y.y.y
Do static (inside,backup) z.z.z.z y.y.y.y
Julio
Do rate all the helpful posts
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
404
