Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA5505 - Enable port forwarding over VPNClient for Remote Desktop?
How can I enable port forwarding of port 3389 to allow Remote Desktop from an outside PC connecting with the VPN client?
1 REPLY
Silver
Re: ASA5505 - Enable port forwarding over VPNClient for Remote D
Port forwarding is the legacy technology for supporting Winsock 2, TCP-based applications over a clientless SSL VPN connection. With port forwarding, remote users may need administrator privileges to connect the local application to the local port.As an administrator configuring port forwarding on the security appliance, you must specify the port the application uses; as an administrator configuring smart tunnel access, you must specify the name of the executable file.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/webvpn.html#wp1291474
214
