ASA5505 error writing to flash file system
Any idea how to work around this error/problem?
ciscoASA5505# reload
System config has been modified. Save? [Y]es/[N]o:Y
%Error opening disk0:/.private/startup-config (Read-only file system)
Error executing command
Proceed with reload? [confirm]
ciscoASA5505#
I'm remote so formating the flash etc is not a good solution.
Thx,
Phil
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: ASA5505 error writing to flash file system
When you perform the reformat, it will repair the faulty file system. If that can't be repaired, you would need to replace the flash.
Unfortunately you only have 2 options in this situation:
1) Reformat the flash
OR/
2) Reload the ASA
Unfortunately none of them is a good solution when you are remote to the ASA.
I was afraid that was my only option.
Actually the unit has been reloaded since the error first appeared, but it persists.
Is is possible to format flash, tftp new IOS/ASDM and startup-config and reload with some assurance that I don't end up with an 'electronic brick'?
When you have issues with your flash, check your flash with fsck.
asafw# fsck disk0:
dosfsck 2.11, 12 Mar 2005, FAT32, LFN
/csco_config/97/bookmarks/Template
  Contains a free cluster (5131). Assuming EOF.
  File size is 881 bytes, cluster chain length is 0 bytes.
  Truncating file to 0 bytes.
Reclaimed 4 unused clusters (32768 bytes) in 2 chains.
Performing changes.
/dev/hda1: 57 files, 12873/31180 clusters
fsck of disk0: complete
3013
