asa5505 nat pat configurations help.
This is my network configuration:
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 192.168.0.7 255.255.255.0
interface Vlan12
no forward interface Vlan1
nameif dmz
security-level 50
ip address 192.168.2.254 255.255.255.0
There must be a communication:
from any inside host -> to outside.
from any dmz host -> to outside.
from any inside host -> to dmz.
using pat
from any outside to some services in inside servers.
these configurations are ok,
but i'm not able to communicate from some servers in dmz to some inside servers which e.g. use smpt, pop3 protocol.
access-list outside_access_in extended permit tcp any host 192.168.0.12 object-group Linuxsrv_servizi
access-list outside_access_in extended permit tcp any host 192.168.0.8 object-group Mailsrv1_servizi
access-list outside extended permit tcp any host 192.168.0.12 eq www
access-list inside_access_in extended permit icmp 192.168.1.0 255.255.255.0 any
access-list inside_access_in extended permit tcp 192.168.1.0 255.255.255.0 any
access-list dmz_access_in extended permit tcp host linuxsrv any eq www
access-list dmz_access_in extended permit tcp host websrv any eq www
access-list dmz_access_in extended permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list dmz_access_in extended permit icmp 192.168.2.0 255.255.255.0 any
access-list dmz_access_in extended permit udp 192.168.2.0 255.255.255.0 any eq domain
This is my nat configuration.
global (outside) 1 192.168.0.8 netmask 255.255.255.0
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 192.168.1.0 255.255.255.0
static (inside,outside) tcp 192.168.0.8 www 192.168.1.201 www netmask 255.255.255.255
static (inside,outside) tcp 192.168.0.8 5500 192.168.1.132 5500 netmask 255.255.255.255
static (inside,outside) tcp 192.168.0.8 smtp 192.168.1.201 smtp netmask 255.255.255.255
static (dmz,outside) 192.168.0.12 linuxsrv netmask 255.255.255.255
static (inside,dmz) 192.168.2.0 192.168.1.0 netmask 255.255.255.0
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
access-group dmz_access_in in interface dmz
route outside 0.0.0.0 0.0.0.0 192.168.0.254 1
Shall i make another nat rule, e.g. from inside to dmz?
i tried to make it but i always get an error.. "this rule is overlapping an existent nat rule"
Could you please tell me where I am wrong?
Kind regards
Re: asa5505 nat pat configurations help.
Are you not able to communicate from any servers in the DMZ to the Inside?
You could try:-
no static (inside,dmz) 192.168.2.0 192.168.1.0 netmask 255.255.255.0
static (inside,dmz) 192.168.2.0 192.168.2.0 netmask 255.255.255.0
HTH.
actually - what might be a little better for troubleshooting is:-
access-list DMZ-NAT-inside extended permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
nat (DMZ) 0 access-list DMZ-NAT-inside
HTH.
You dont have Security Plus License for your ASA 5505. In base license DMZ capabilities are limited. You may need to upgrade your ASA license to security plus.
i've just installed Security Plus License 2 days ago.
i'll try configurations suggested next Monday.
Thanks a lot.
Best Regards
Mirco
You were right. I did activate the License, but I did not save the unlock of the traffic from Dmz to Inside.
Thank you again,
Mirco Frazzoni
Thank you, I've followed your advice and now it works. However, I actually had another problem: I bought ASA 5505 with DMZ restricted, activated Security Plus (DMZ unrestricted), but I forgot to enable the traffic from DMZ to Inside and to save it in my configuration.
Mirco Frazzoni
So is the problem fixed - of do you have another issue?
Now all works fine.
Thanks.
210
