Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA5505 site to site - vlan not communicating
I got two asa 5505 - with security plus
ASA8.43 - ASDM 6.47
I have three vlans that need to communicate over the vlan.
                                                  SiteA          Site B
1.  Inside vlan11               192.168.11.1 to 192.168.10.1 - this pings just fine from one end of the tunnel to the other.
2   DMZ vlan12                 10.10.10.1 to 10.10.10.6   This will not ping the other side of the dmz
3.  Management vlan 13  192.168.0.1 to 192.168.0.2  this will ping the inside vlan , but will not ping DMZ or Management from one side of the tunnel.
All three vlans have dynamic nat to the outside for internet access
I use a wirless lan controller from site A and want to control WAP on site B
The DMZ from site B - has to communicate with a DHCP server on Site A - I think I got the ACL correct on this on router A, so after the nat issue is fixed it should work.
router A is working correctly - packet trascer shows the packet going through the vpn lookup
Router B will not translate dmz or management traffic to the vpn lookup - I DONT KNOW WHY!!!!
Here is the config for Router B
: Saved
ASA Version 8.4(3)
hostname lyons5505
names
name 192.168.10.0 Inside
name 192.168.0.0 Management
name 192.168.10.2 CPLserver
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
 switchport trunk allowed vlan 11-13
 switchport mode trunk
interface Ethernet0/2
 switchport access vlan 11
interface Ethernet0/3
interface Ethernet0/4
 switchport access vlan 13
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 shutdown
 nameif default
 security-level 10
interface Vlan2
 nameif outside
 security-level 0
 ip address dhcp setroute
interface Vlan11
 description Inside
 nameif inside
 security-level 90
 ip address 192.168.11.1 255.255.255.0
interface Vlan12
 nameif dmz
 security-level 50
 ip address 10.10.10.6 255.255.255.0
interface Vlan13
 description Management
 nameif Management
 security-level 100
 ip address 192.168.0.2 255.255.255.0
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network Inside
 subnet 192.168.11.0 255.255.255.0
object network Management
 subnet 192.168.0.0 255.255.255.0
object network In_to_out_NAT
 subnet 0.0.0.0 0.0.0.0
object network inside_to_out
 host 192.168.11.13
object network local-lan
object network CPL
 subnet 192.168.10.0 255.255.255.0
object network obj-192.168.11.0
object network obj-192.168.0.0
object network management
object network obj-10.10.10.0
 subnet 10.10.10.0 255.255.255.0
object network DMZ
object network Atlantis
 host 192.168.10.13
object network Columbus
 host 192.168.11.2
object network CPLDHCP
 host 192.168.10.2
object network in_to_out_NAT
object-group network obj-10.0.1.0
object-group network obj-10.0.2.0
object-group network CPL_VPN
 network-object Inside 255.255.255.0
object-group network DMZ_VPN
 network-object 10.10.10.0 255.255.255.0
object-group network Management_VPN
 network-object Management 255.255.255.0
object-group network INSIDE_VPN
 network-object 192.168.11.0 255.255.255.0
object-group network DM_INLINE_NETWORK_1
 group-object DMZ_VPN
 group-object INSIDE_VPN
 group-object Management_VPN
object-group network DM_INLINE_NETWORK_2
 group-object CPL_VPN
object-group network DM_INLINE_NETWORK_3
object-group network DM_INLINE_NETWORK_4
object-group network DM_INLINE_NETWORK_5
object-group network Outside
 description Needed for DMZ outside access - Dont know why
 network-object object in_to_out_NAT
access-list INSIDE-NAT0 remark NO NAT between Local Networks
access-list DMZ-NAT0 remark NO NAT between Local Networks
access-list MANAGEMENT-NAT0 remark NO NAT between Local Networks
access-list outside_cryptomap extended permit ip object-group DM_INLINE_NETWORK_1 object-group DM_INLINE_NETWORK_2
access-list global_mpc extended permit ip object-group INSIDE_VPN object-group CPL_VPN inactive
access-list global_mpc_1 extended permit ip object-group INSIDE_VPN object-group CPL_VPN inactive
access-list global_mpc_2 extended permit ip object-group INSIDE_VPN object-group CPL_VPN inactive
access-list outside_mpc extended permit ip any object CPL inactive
access-list dmz_access_in extended permit ip object DMZ object Columbus
access-list dmz_access_in extended deny ip object DMZ object Inside
pager lines 24
logging enable
logging timestamp
logging asdm-buffer-size 512
logging buffered debugging
logging asdm debugging
mtu default 1500
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu Management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any dmz
icmp permit any Management
no asdm history enable
arp timeout 14400
nat (any,outside) source static DM_INLINE_NETWORK_4 DM_INLINE_NETWORK_4 destination static DM_INLINE_NETWORK_5 DM_INLINE_NETWORK_5
 nat (inside,outside) dynamic interface
 nat (Management,outside) dynamic interface
 nat (dmz,outside) dynamic interface
access-group dmz_access_in in interface dmz
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http Management 255.255.255.240 Management
http Management 255.255.255.0 Management
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set L2L esp-aes-256 esp-sha-hmac
crypto ipsec ikev2 ipsec-proposal test
 protocol esp encryption 3des
 protocol esp integrity md5
crypto ipsec ikev2 ipsec-proposal AES256
 protocol esp encryption aes-256
 protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
 protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
crypto ipsec ikev2 ipsec-proposal DES
 protocol esp encryption des
crypto map lyons.dnsget.org 1 set ikev1 transform-set ESP-3DES-SHA
crypto map outside_map0 1 match address outside_cryptomap
crypto map outside_map0 1 set peer xxx.xxx.xxx.xxx
crypto map outside_map0 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map0 interface outside
crypto ikev2 policy 1
 encryption aes-256
 integrity sha
 group 5 2
 prf sha
 lifetime seconds 86400
crypto ikev2 policy 10
 encryption aes-192
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 20
 encryption aes
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 30
 encryption 3des
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 40
 encryption des
 integrity sha
 group 5 2
 prf sha
crypto ikev1 enable outside
crypto ikev1 policy 1
 authentication pre-share
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 10
 encryption des
 hash sha
 group 2
 lifetime 86400
telnet 192.168.0.200 255.255.255.255 Management
telnet 192.168.0.201 255.255.255.255 Management
telnet Management 255.255.255.0 Management
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd auto_config outside interface Management
dhcprelay server CPLserver inside
dhcprelay enable Management
dhcprelay timeout 60
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
group-policy DfltGrpPolicy attributes
 dns-server value 192.168.10.9
 vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-clientless
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
 wins-server none
 vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-client ssl-clientless
 default-domain none
username padmin password 33TXuC/dbIFJdJDc encrypted privilege 15
username cisco password 3USUcOPFUiMCO4Jk encrypted
username cisco attributes
 service-type nas-prompt
tunnel-group DefaultL2LGroup ipsec-attributes
 ikev1 pre-shared-key *****
tunnel-group xxx.xxx.xxx.xxx type ipsec-l2l
tunnel-group xxx.xxx.xxx.xxx ipsec-attributes
class-map inspection_default
 match default-inspection-traffic
class-map outside-class
 match access-list outside_mpc
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
  inspect icmp error
policy-map outside-policyQOS
 class outside-class
  police input 512000 1500
  police output 512000 1500
  set connection conn-max 200 embryonic-conn-max 200 per-client-max 40 per-client-embryonic-max 40
service-policy global_policy global
service-policy outside-policyQOS interface outside
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:06061a4998455a9bb099a2704bac6efc
: end
Everyone's tags (4)
1 ACCEPTED SOLUTION
Super Bronze
Well that is one clear problem atleast.
You should use different networks/subnets on each side since these networks dont have a L2 connectivity to enable sharing the subnet/address space.
You could naturally avoid changing IP addressess/subnets by NATing the overlapping networks
- Jouni
Super Bronze
Re: ASA5505 site to site - vlan not communicating
There is quite a bit of different things mentioned in your post.
First thing we should clear up is that are you actually using overlapping networks on the 2 sites? The start of the post seems to indicate that both DMZ and MANAGEMENT networks are the same on both sites?
- Jouni
Yes , Correct both the DMZ and Management networks are the same IP scheme.
Super Bronze
- Jouni
Thankyou sir.  I changed the DMZ network at site b and changed both routers configs and the wireless access point is communicating the the wireless lan controller.  My issue is resolved.
188
