Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA5505 SOHO public ip range and nat head ache
Hello
Can anyone shed some ligh on a problem im having. We have setup a ASA 5505 with an ISP called Zen that allocates you a subnet of public ip addresses. i have sucessfully  setup the asa to access the internet using nat on the outside interface. we would like to use the other ip addresses in the range for other services but i cannot think how i can do this/configure this.
LAN > ASA5505 > VDSL Modem > ISP
the range they have given us is
Number of IP addresses: 8
IP addresses: XX.XX.XXX.40 - XX.XX.XXX.47
Subnet mask: 255.255.255.248
Subnet in slash notation: XX.XX.XXX.40 /29
Network address: XX.XX.XXX.40
XX.XX.XXX.41
XX.XX.XXX.42
XX.XX.XXX.43
XX.XX.XXX.44
XX.XX.XXX.45
XX.XX.XXX.46 Router
Broadcast address: XX.XX.XXX.47
Router address: XX.XX.XXX.46
i have setup XX.XX.XXX.46 on the otside interface and hosts inside can access the net and nat from the internet to internal devices all work.
we have a vdsl modem connected to the outside interface and using PPPoE we dynamically get the XX.XX.XXX.46/32 address.
Is there any way i can use the other spare addresses? i do see how i can use them. i have done a lot of browsing and the only way i see that other people have been able to do this is using a layer3 device and using ip unnumber of the external int point to a loopback,
any info or advice would be gratefully received.
regards
C.
Everyone's tags (1)
Hi, Since you have the public
Since you have the public subnet pointed to your asa outside interface ip from your isp..... so you do not need to worry about anything..... you can use other ip addresses for your NAT/PAT.... for testing you can remove the NAT statement as interface to a different ip in that stack....
say nat (inside,outside) dynamic <x.x.x.41>
It will work.... in case if you want to use the spare ip address for a servers inside the network.... you need to do the static nat.... for those servers with that ip range..... allow the required traffic to the server on outside interface acl....
Karthik
Hellothe version is Cisco
:edit
VIP Purple
In a scenario like yours, it
In a scenario like yours, it's very likely that the provider has routed the extra network to your PPPoE assigned address. with that you need three config-elements (I assume you are running an actual ASA v8.4 or newer):
  1. arp permit-nonconnected
  2. NAT-statements for your servers
  3. ACL-staement on the outside-ACL to allow the communication
Hello
the version is Cisco Adaptive Security Appliance Software Version 9.2(2)4
debugging icmp i see pings to the .46 address however i see no pings/traffic received on the asa for the other addresses. how does zen know to route the xx.xx.xx.41 to .45 ip addresses to the firewall using the .46 address?
the nat rules i have are
nat (Vlan200_Int,Outside_Dirty_Int) dynamic interface < this works for lan access to the internet
nat (Vlan200_Int,Outside_Dirty_Int) static xx.xx.xx.45 no-proxy-arp service tcp www 65100
nat (Vlan200_Int,Outside_Dirty_Int) static xx.xx.xx.45 no-proxy-arp service tcp https 65101
access-list Outside_Dirty_Network_access_in extended permit tcp object Click_PC object ESXi object-group DM_INLINE_TCP_7
object-group service DM_INLINE_TCP_7 tcp
port-object eq 902
port-object eq www
port-object eq https
thanks for the help
Hi,If you procure a subnet
If you procure a subnet from ISP, it should be routed to your device from their subnet...
You can ping x.x.x.46 because it is a connected interface ip.... you cannot ping the other one because you have just allowed for port forwarding..... it cannot be checked with ping.....
to test that you should do....
from outside pc.... do telnet x.x.x.45 80 / telnet x.x.x.45 443 else do a real test using browser.....
Karthik
thank you for the advice,
thank you for the advice, this is now working. using the telnet test worked and i was baffled not being able to ping the ip when that would never be possible.
thank you agian
c.
VIP Purple
That's their task to configure it.
have you configured arp permit-nonconnected? After thinking twice again, that's not needed in this scenario when the network is routed to the ASA.
And it seems that your ACL/NAT doesn't allow icmp/echo.
Why have you configured no-proxy-arp on your nat-rules?
thank you for the reply and
thank you for the reply and the info, i have now got it working :)
111
