Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA5505 Upgrade to 9.1.5 from 8.4.1 - problem with nat and accessing external host
When running on 8.4 i had a working config with the following scenario.
I have 2 interfaces configured as the outside interface.
One is connected to my internet connection
The other one is connected to a host that has a public ip.
The public host can access internet and also a PAT port on an internal host.
But after the upgrade the internal hosts can't access the external host but everything else on internet
packet-tracer input inside tcp 10.x.x.11 1024 x.x.x.89 22
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   x.x.x.0    255.255.240.0   outside
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (nat-no-xlate-to-pat-pool) Connection to PAT address without pre-existing xlate
If i add 1 to the destination ip:
packet-tracer input inside tcp 10.x.x.11 1024 x.x.x.90 22
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group inside_access_in in interface inside
access-list inside_access_in extended permit ip any4 any4
Phase: 3
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (inside,outside) source dynamic any interface
Dynamic translate 10.x.x.11/1024 to x.x.x.80/1024
Phase: 4
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 7
Type: USER-STATISTICS
Subtype: user-statistics
Result: ALLOW
Config:
Phase: 8
Type: NAT
Result: ALLOW
Config:
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Result: ALLOW
Config:
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 98586, packet dispatched to next module
Result:
input-status: up
output-status: up
Action: allow
Nat rules:
nat (inside,outside) source static IPv6_HOST interface service https https
nat (inside,outside) source static IPv6_HOST interface service http http
nat (inside,outside) source static IPv6_HOST interface service ssh ssh
nat (inside,outside) source static INTERNAL interface destination static EXTERNAL EXTERNAL service apcupsd apcupsd
nat (inside,outside) source static IPv6_HOST interface destination static IPv6_POP IPv6_POP
The EXTERNAL is the host that is connected to an outside interface and that NAT rule works ok.
I can ping the EXTERNAL host from the ASA but not from the internal network.
Any ideas would be appreciated.
1 REPLY
Community Member
Hmmm, by adding the following
Hmmm, by adding the following i got it working:
nat (inside,outside) source dynamic inside interface destination static EXTERNAL EXTERNAL
It is a bit complicated though since the EXTERNAL host get it's address via DHCP and so does the ASA.
166
