ASA5510 ASA5510-K8 LAN Failover
mwheinz
Can these 2 models do LAN failover provided images and licensing are correct? The firewalls are identical except for the show version models, one is the "K8" variant, whatever that is.
Thanks!
Thanks for your reply. The referenced doc really doesn't say if the asa5510 and the asa5510-k8 are interoperable as regards failover. Have you set this up using the models in question?
Thanks!
The ASA5510 and the ASA5510-K8 are the same hardware models. They both need to run the exact same OS for failover. Upgrade to 8.2(x) if possible.
FIREWALL# sh ver
Cisco Adaptive Security Appliance Software Version 8.2(1)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
FIREWALL up 26 days 4 hours
failover cluster up 1 year 21 days
Hardware: ASA5510-K8, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
Slot 1: ATA Compact Flash, 64MB
BIOS Flash AT49LW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: Ethernet0/0 : address is 0019.e8d9.46f2, irq 9
1: Ext: Ethernet0/1 : address is 0019.e8d9.46f3, irq 9
2: Ext: Ethernet0/2 : address is 0019.e8d9.46f4, irq 9
3: Ext: Ethernet0/3 : address is 0019.e8d9.46f5, irq 9
4: Ext: Management0/0 : address is 0019.e8d9.46f1, irq 11
5: Int: Internal-Data0/0 : address is 0000.0001.0002, irq 11
6: Int: Internal-Control0/0 : address is 0000.0001.0001, irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 100
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
SSL VPN Peers : 2
Total VPN Peers : 250
Shared License : Disabled
AnyConnect for Mobile : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions : 2
Total UC Proxy Sessions : 2
Botnet Traffic Filter : Disabled
This platform has an ASA 5510 Security Plus license.
Serial Number: 99999999
Running Activation Key: XXXX XXXX XXXX XXXX XXXX
FW# sh fail state
State Last Failure Reason Date/Time
This host - Primary
Active None
Other host - Secondary
Standby Ready Comm Failure 06:10:17 CST May 17 2009
====Configuration State===
Sync Done
Sync Done - STANDBY
====Communication State===
Mac set
