ASA5510 not reaching a particular IP
I hope you can help me do bear with me as I'm still starting with Cisco products,
We have a Cisco ASA 5510 Base License with 7.08 our provider assigned us x.x.199.41 as gateway while the ASA is on x.x.199.42 in the 255.255.255.248 subnet... I tried mapping our servers with x.x.199.43 on server1 and x.x.199.44 on server2... server2 can be reached from outside while server1 is unreacheable and our provider is insisting the issue is with our firewall configuration below is our running config.. hope anyone can point me in the right direction... thanks!
ASA Version 7.0(8)
names
dns-guard
interface Ethernet0/0
nameif Public
security-level 0
ip address x.x.199.42 255.255.255.248
interface Ethernet0/1
nameif Private
security-level 5
ip address 192.168.10.250 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address x.x.0.1 255.255.255.0
management-only
ftp mode passive
object-group network inside-network
access-list Private_access_in extended permit ip any any
access-list Private_access_in extended permit icmp any any
access-list Private_access_out extended permit ip any any
access-list Private_access_out extended permit icmp any any
access-list Public_access_in extended permit ip any any
access-list Public_access_in extended permit icmp any any
access-list Public_access_out extended permit ip interface Public any
access-list Public_access_out extended permit icmp interface Public any
access-list MYLIST1 extended permit ip 192.168.10.0 255.255.255.0 192.168.1.0
255.255.255.0
access-list NONAT extended permit ip 192.168.10.0 255.255.255.0 192.168.1.0
255.255.255.0
access-list NONAT extended permit ip 192.168.10.0 255.255.255.0 192.168.6.0
255.255.255.0
access-list NONAT extended permit ip 192.168.10.0 255.255.255.0 192.168.7.0
255.255.255.0
access-list NONAT extended permit ip 192.168.10.0 255.255.255.0 192.168.100.0
255.255.255.0
access-list MYLIST2 extended permit ip 192.168.10.0 255.255.255.0 192.168.6.0
255.255.255.0
access-list MYLIST3 extended permit ip 192.168.10.0 255.255.255.0 192.168.7.0
255.255.255.0
192.168.100.0 255.255.255.0
pager lines 24
logging asdm informational
mtu Public 1500
mtu Private 1500
mtu management 1500
no asdm history enable
arp timeout 14400
global (Public) 1 interface
nat (Private) 0 access-list NONAT
nat (Private) 1 0.0.0.0 0.0.0.0
static (Private,Public) x.x.199.44 192.168.10.252 netmask 255.255.255.255
static (Private,Public) x.x.199.43 192.168.10.251 netmask 255.255.255.255
access-group Private_access_in in interface Public
access-group Private_access_in out interface Public
access-group Private_access_in in interface Private
access-group Private_access_in out interface Private
route Public 0.0.0.0 0.0.0.0 x.x.199.41 1
route Public 192.168.1.0 255.255.255.0 x.x.6.160 1
route Public 192.168.6.0 255.255.255.0 x.x.135.113 1
route Public 192.168.7.0 255.255.255.0 x.x.197.68 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set MYSET esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 3600
crypto ipsec security-association lifetime kilobytes 4608000
crypto map MYMAP 10 match address MYLIST1
crypto map MYMAP 10 set peer x.x.6.27
crypto map MYMAP 10 set transform-set MYSET
crypto map MYMAP 10 set security-association lifetime seconds 3600
crypto map MYMAP 10 set security-association lifetime kilobytes 4608000
crypto map MYMAP 20 match address MYLIST2
crypto map MYMAP 20 set peer x.x.135.113
crypto map MYMAP 20 set transform-set MYSET
crypto map MYMAP 20 set security-association lifetime seconds 3600
crypto map MYMAP 20 set security-association lifetime kilobytes 4608000
crypto map MYMAP 30 match address MYLIST3
crypto map MYMAP 30 set peer x.x.197.68
crypto map MYMAP 30 set transform-set MYSET
crypto map MYMAP 30 set security-association lifetime seconds 3600
crypto map MYMAP 30 set security-association lifetime kilobytes 4608000
crypto map MYMAP interface Public
isakmp identity address
isakmp enable Public
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp nat-traversal  20
tunnel-group x.x.6.27 type ipsec-l2l
tunnel-group x.x.6.27 ipsec-attributes
pre-shared-key *
tunnel-group x.x.135.113 type ipsec-l2l
tunnel-group x.x.135.113 ipsec-attributes
pre-shared-key *
tunnel-group x.x.197.68 type ipsec-l2l
tunnel-group x.x.197.68 ipsec-attributes
pre-shared-key *
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect dns maximum-length 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
service-policy global_policy global
Cryptochecksum:dc521e98e6fa2918e524835d45dbd0e0
: end
Everyone's tags (6)
1 REPLY
Super Bronze
Re: ASA5510 not reaching a particular IP
The "static" statement seems to be normal atleast. (Though we can't see the whole statement. But I assume you've made sure the public IP is entered correctly)
Your ACL setup seems strange though.
You are using the same access-list for both interfaces for both directions.
This is just my personal opinion but you will be fine with using a separate access-list for both interfaces and only apply them to "in" direction.
My basic access-list that I do is INSIDE-IN and OUTSIDE-IN and have the interface names as "inside" and "outside". Configuration stays really simple.
Also your security-level configurations seem abit unsual (although I guess it doesnt really cause any problems in this case) Again, the very basic setup would be to have "inside" as "100" and "outside" as "0"
Personally I would first have someone try connection to the service that you are running on the server thats not working. At the same time I would open the ASAs ASDM and see from the monitoring what is happening to the connection. Is it showing up on the firewall and if it is, what is happening to the connection.
I'm not sure if the "packet-tracer" command was included in the 7.0 software (didn't find it in the command reference for 7.0 atleast) but if it does exist in your software, try to command out and see whats happening to the connections from outside.
Also doing a traffic capture would be one option.
http://www.cisco.com/en/US/docs/security/asa/asa70/command/reference/c.html#wp1950270
Also does the problem server have its default gateway set correctly? As you are using an address ending with .250 as the ASA interface IP address. Though this question is due to my personal preference again since I usually use the first address after the network address as the interface address.
- Jouni
398
