ASA5510 SMTP problems
Up until recently one of my sites was able to get to a postini subnet. Then we started recieving "host unreachable" e-mails. Postini told us SMTP traffic was not getting let in. I've compared the current config to a config that was saved before the issue popped up and found really no noticeable difference.
I tried a packet tracer trace with no luck:
SiteB-Firewall# packet-tracer input outside tcp 11.2.2.36 12345 65.19.0.0 25
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Attached is a sanitized config. I'm not entirely convinced it's a firewall issue, but I need to some successful testing to prove otherwise.
Everyone's tags (5)
So only the subnet 65.19.0.0 255.255.240.0 should be able to access the SMTP server?
The packet tracer is not properly build
Try this one
packet-tracer input outside tcp 65.19.0.30 1025 25.107.253.3 eq 25
Right now your ASA is setup to allow connections only from 65.19.0.0 255.255.240.0 to the SMTP server.
Rate all the helpful posts
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Julio, yes, only that subnet should be able to reach my SMTP server.
Here's the packet trace:
SiteB-Firewall# packet-tracer input outside tcp 65.19.0.30 1025 25.107.$
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
static (inside,outside) tcp interface smtp 11.2.2.36 smtp netmask 255.255.255.255
nat-control
  match tcp inside host 11.2.2.36 eq 25 outside any
    static translation to 25.107.253.3/25
    translate_hits = 0, untranslate_hits = 9453
NAT divert to egress interface inside
Untranslate 25.107.253.3/25 to 11.2.2.36/25 using netmask 255.255.255.255
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group incoming in interface outside
access-list incoming extended permit tcp object-group Postini interface outside eq smtp
object-group network Postini
network-object 65.19.0.0 255.255.240.0
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 6
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
nat-control
Phase: 7
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
nat-control
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 41247, packet dispatched to next module
Result:
input-status: up
output-interface: inside
output-status: up
Action: allow
If I'm understanding this right, we're testing to make sure the outside interface and my postini subnet can talk. That looks like that was successful, that's good, but only half of the communication.
Testing the other half of the coummuncation, if all of my assumptions have been correct, is making sure the outside interface passes the SMTP traffic back correctly to the inside network. Below is the packet trace I tried, it failed:
SiteB-Firewall# packet-tracer input inside tcp 24.106.253.3 1025 11.2.2$
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   11.2.2.0        255.255.255.0   inside
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: NAT
Result: ALLOW
Config:
nat (inside) 0 0.0.0.0 0.0.0.0
nat-control
  match ip inside any BAD_INT_1 any
    no translation group, implicit deny
    policy_hits = 0
Phase: 7
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
nat (inside) 1 11.2.2.0 255.255.255.0
nat-control
  match ip inside 11.2.2.0 255.255.255.0 inside any
    dynamic translation to pool 1 (No matching global)
    translate_hits = 0, untranslate_hits = 0
Result:
input-interface: inside
input-status: up
output-status: up
Action: drop
What's our next step?
Just got a Mail Host Unreachable email from Postini so were the packet tracer results incorrect then?
Can anyone make heads or tails of that last packet tracer output?
Hello Adam,
Sorry I could not respond this before, I was working on some other things.
You are using Port-forwarding to make this happen.
     Por-forwarding is only used for incoming connections, for outbound connections the server will use a PAT or NAT rule.
So as we can see on packet tracer 1 everything looks good from the ASA perspective.
     1-Traffic arrives on the outside interface on por 25
     2-ASA checks the ACL and allows the packet
     3-ASA does the right nat tranlastion
     4-ASA creates an entry on the XLATE, CONN and Local-Host table
     5-ASA send's the packet out the right interface
     6-ASA receives the response from the SMTP server, based on the entry on the XLATE and CONN table he will         perform the nat for the reply
     7-Packet will reach the outside client
Why is the second PT not working?
     A/Because as I said you have a port-forwarding rule for the SMTP server and that only works for incoming traffic
        not outbound traffic ( to make it work you will need to add a Global statement but this will not solve the problem)
Please add the following
capture capout interface outside trace match tcp any host interface_ip eq 25
capture capin interface inside trace match tcp any host SMTP_SERVER_IP eq 25
Then generate the traffic and provide us the :
     -Show cap capout
     -Show cap capin
Julio
Julio Carvajal
Re: ASA5510 SMTP problems
@jcarvaja I'll try that next.
Here's the test from the outside interface, it fails as well.
SiteB-Firewall# packet-tracer input outside tcp 24.106.253.3 1025 11.2.2.36 25 detail
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Forward Flow based lookup yields rule:
in  id=0xd7c09ef8, priority=11, domain=permit, deny=true
        hits=39, user_data=0x5, cs_id=0x0, flags=0x0, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Result:
input-status: up
output-status: up
Action: drop
What do I need to try next in this config?
Hello Adam,
add the following
access-list incoming line 1 permit ip any host 11.2.2.36 25
Julio Carvajal
Here's the results:
SiteB-Firewall# capture capout interface outside trace match tcp any host 25.107.253.3 eq 25
SiteB-Firewall# capture capin interface inside trace match tcp any host 11.2.2.36 eq 25
NOTE: I did not manually generate traffic here.
SiteB-Firewall# sh cap capin
2 packets captured
   1: 14:26:39.200154 65.19.1.143.35442 > 11.2.2.36.25: S 1481583325:1481583325(0) win 5744
   2: 14:26:39.682948 65.19.1.134.40522 > 11.2.2.36.25: S 688312206:688312206(0) win 5744
2 packets shown
SiteB-Firewall# sh cap capout
5 packets captured
   1: 14:26:33.201710 65.19.1.143.35442 > 25.107.253.3.25: S 3750468370:3750468370(0) win 5744
   2: 14:26:33.683085 65.19.1.134.40522 > 25.107.253.3.25: S 15701922:15701922(0) win 5744
   3: 14:26:34.168051 65.19.1.159.33872 > 25.107.253.3.25: S 422177870:422177870(0) win 5744
   4: 14:26:39.200062 65.19.1.143.35442 > 25.107.253.3.25: S 3750468370:3750468370(0) win 5744
   5: 14:26:39.682871 65.19.1.134.40522 > 25.107.253.3.25: S 15701922:15701922(0) win 5744
5 packets shown
SiteB-Firewall#
SiteB-Firewall# SiteB-Firewall# packet-tracer input outside tcp 25.107.253.3 1025 11.2.2.36 25 detail
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
in  id=0xd84e46f0, priority=12, domain=capture, deny=false
        hits=4963, user_data=0xd7c01278, cs_id=0x0, l3_type=0x0
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0xd7b31b58, priority=1, domain=permit, deny=false
        hits=129043, user_data=0x0, cs_id=0x0, l3_type=0x8
Phase: 3
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 5
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0xd7b375a0, priority=500, domain=permit, deny=true
        hits=1, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=25.107.253.3, mask=255.255.255.255, port=0
Result:
input-status: up
output-status: up
Action: drop
10 packets captured
   3: 14:26:51.200276 65.19.1.143.35442 > 11.2.2.36.25: S 1481583325:1481583325(0) win 5744
   4: 14:26:51.680201 65.19.1.134.40522 > 11.2.2.36.25: S 688312206:688312206(0) win 5744
   5: 14:26:58.167883 65.19.1.159.33872 > 11.2.2.36.25: S 691920151:691920151(0) win 5744
   6: 14:27:15.197774 65.19.1.143.35442 > 11.2.2.36.25: S 1326979564:1326979564(0) win 5744
   7: 14:27:15.677867 65.19.1.134.40522 > 11.2.2.36.25: S 330226058:330226058(0) win 5744
   8: 14:27:46.166983 65.19.1.159.33872 > 11.2.2.36.25: S 1755337294:1755337294(0) win 5744
   9: 14:28:03.191899 65.19.1.143.35442 > 11.2.2.36.25: S 465997866:465997866(0) win 5744
  10: 14:28:03.670299 65.19.1.134.40522 > 11.2.2.36.25: S 1234871544:1234871544(0) win 5744
10 packets shown
13 packets captured
   6: 14:26:51.200200 65.19.1.143.35442 > 25.107.253.3.25: S 3750468370:3750468370(0) win 5744
   7: 14:26:51.680125 65.19.1.134.40522 > 25.107.253.3.25: S 15701922:15701922(0) win 5744
   8: 14:26:58.167639 65.19.1.159.33872 > 25.107.253.3.25: S 422177870:422177870(0) win 5744
   9: 14:27:15.197530 65.19.1.143.35442 > 25.107.253.3.25: S 3750468370:3750468370(0) win 5744
  10: 14:27:15.677653 65.19.1.134.40522 > 25.107.253.3.25: S 15701922:15701922(0) win 5744
  11: 14:27:46.166769 65.19.1.159.33872 > 25.107.253.3.25: S 422177870:422177870(0) win 5744
  12: 14:28:03.191670 65.19.1.143.35442 > 25.107.253.3.25: S 3750468370:3750468370(0) win 5744
  13: 14:28:03.670070 65.19.1.134.40522 > 25.107.253.3.25: S 15701922:15701922(0) win 5744
13 packets shown
Hello Adam,
Can you install wireshark on the server and run a capture?
Based on the captures packets are reaching the server but there is no reply
Julio
Julio Carvajal
Results:
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
        hits=245849, user_data=0xd7c01278, cs_id=0x0, l3_type=0x0
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
        hits=131772, user_data=0x0, cs_id=0x0, l3_type=0x8
Phase: 3
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 5
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-list incoming extended permit tcp any host 11.2.2.36 eq smtp
in  id=0xd7b3c5f8, priority=12, domain=permit, deny=false
        hits=0, user_data=0xd6874100, cs_id=0x0, flags=0x0, protocol=6
        dst ip=11.2.2.36, mask=255.255.255.255, port=25, dscp=0x0
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xd7b347d0, priority=0, domain=permit-ip-option, deny=true
        hits=14315, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 7
Type: VPN
Result: ALLOW
Config:
in  id=0xd83106c8, priority=12, domain=ipsec-tunnel-flow, deny=true
        hits=11490, user_data=0x0, cs_id=0x0, flags=0x0, protocol=0
Phase: 8
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
out id=0xd84e3c28, priority=12, domain=capture, deny=false
        hits=372, user_data=0xd7c01bf8, cs_id=0xd84e3538, reverse, flags=0x0, protocol=6
Phase: 9
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
nat-control
    translate_hits = 0, untranslate_hits = 11143
out id=0xd7bfb070, priority=5, domain=nat-reverse, deny=false
        hits=11104, user_data=0xd7bfacf0, cs_id=0x0, flags=0x0, protocol=6
Result:
input-status: up
output-status: up
Action: drop
@jcarvaja: That last capture was after adding the line: access-list incoming line 1 permit ip any host 11.2.2.36 25
To my ACL.
Do you see anything on the captures or packet-trace that would help me out or at least point me in the right direction?
Hello Adam,
The packet tracer's and captures are not the right ones:
no cap capout
no cap capin
cap capout interface outside trace match tcp any host 11.255.2.1 eq 25
cap capin interface inside trace match tcp any host 11.2.2.36 eq 25
packet-tracer input tcp 25.107.253.3 1025 11.255.2.1 25
Julio
Julio Carvajal
SiteB-Firewall# packet-tracer input outside tcp 25.107.253.3 1025 11.255.2.1 25
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
MAC Access list
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 3
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   11.255.2.1      255.255.255.255 identity
Phase: 5
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-status: up
output-interface: NP Identity Ifc
output-status: up
Action: drop
SiteB-Firewall# sh capture capin
0 packet captured
0 packet shown
SiteB-Firewall# sh capture capout
1 packet captured
   1: 16:39:58.911543 24.106.253.3.1025 > 10.255.2.1.25: S 1576173544:1576173544(0) win 8192
1 packet shown
Hello Adam,
I just reviewed the entire configuration one more time and I saw what is going on here.
Please remove the entire captures one more time:
no cap capin
no cap capout
You are trying to connect from the outside world to the following IP:11.255.2.1
-That ip belongs to  the inside interface.
          *****ASA speaking, you will not be able to access a distant interface***********
                         example: from a inside host you cannot ping or ssh or telnet the outside interface
                         example 2: from the outside world you will not be able to ping or ssh or telnet the outside interface
You will need to connect to this IP address  25.107.253.3
That is why you have : static (inside,outside) tcp interface smtp 11.2.2.36 smtp netmask 255.255.255.255
So:
1-access-list incoming permit tcp any host 11.2.2.36
2- packet-tracer input outside tcp 4.2.2.2 1025 25.107.253.3 and provide me the result
3- cap capout interface outside match tcp any host 25.107.253.3 eq 25
4-cap capin interface inside match tcp any host 11.2.2.36 eq 25
5-Generate real traffic
6-Send me the show cap capin, show cap capout
Julio
CSC it's a free support community take your time to rate all the engineer's responses that help you resolving your problems.
Julio Carvajal
Reconfigured NAT to use seperate public IP addresses for our mail (SMTP) and RDP, using the following commands on the existing config:
no static (inside,outside) tcp interface 3389 11.22.33 3389 netmask 255.255.255.255
no static (inside,outside) tcp interface smtp access-list postini-nat
static (inside,outside) 25.107.253.4 11.22.33 netmask 255.255.255.255
static (inside,outside) 25.107.253.5 11.22.36 netmask 255.255.255.255
access-list incoming extended permit tcp any host 25.107.253.4 eq 3389
access-list incoming extended permit tcp 65.19.0.0 255.255.240.0 host 25.107.253.5 eq smtp
access-list incoming extended permit icmp any any
These commands did not let the mail through. In addition, after restarting the router, now the firewall can't get to anything on the internal network and I can't remote directly into it. I have to telnet into it through the local router.
Attached is sanitized config of that router. I need to figure out why the mail isn't getting through and additionally why now the firewall can't get into the internal network.
Ping results:
Router to inside int of Firewall: Good
Rtr to outside int of FW: Good
Rtr to IPS address (past FW): Good
Firewall to router on int that connects the 2: Good
FW to RTR int on the internal network: Fail
FW to RTR's mpls port: Fail
FW to internal network address (it's own Site): Fail
FW to internal network address (another site): Fail
Tried "clear xlate", have not power cycled the ASA though.
More output:
SiteB-Firewall# sh eigrp neighbors
EIGRP-IPv4 neighbors for process 102
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
0   11.255.2.2              Et0/1            14  19:25:28 2    200   0   11
SiteB-Firewall# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 25.107.253.1 to network 0.0.0.0
C    25.107.253.0 255.255.255.248 is directly connected, outside
C    11.255.2.0 255.255.255.252 is directly connected, inside
S*   0.0.0.0 0.0.0.0 [1/0] via 25.107.253.1, outside
SiteB-Firewall# sh eigrp topology
EIGRP-IPv4 Topology Table for AS(102)/ID(25.107.253.3)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 0.0.0.0 0.0.0.0, 1 successors, FD is 28160
        via Rstatic (28160/0)
P 11.255.2.0 255.255.255.252, 1 successors, FD is 2816
        via Connected, Ethernet0/1
Complete updated ASA config attached.
942
