ASA5510 Static 1to1 NAT Configuration Issue
We are replacing our EOL Watchguard X1000 Firewall(s) with Cisco ASA 5510 unit - ASA Version 8.4(3).  Following is the static NAT I have build and the corresponding access list.
nat (FW2Inside,FW2Outside) source static BW_XSP1_Private BW_XSP1_Public destinat
ion static BW_XSP1_Private BW_XSP1_Public
access-list FW2Outside_access_in extended permit tcp any object BW_XSP1_Public object-group DM_INLINE_TCP_1
Unable to access the server on the inside interface via the public NAT address. Can you point me in the right direction as to what I might be missing to make this work?
Everyone's tags (2)
1 REPLY
Red
Hi David,
You need to use these:
nat (FW2Outside,FW2Inside) source static any any destination static BW_XSP1_Public BW_XSP1_Private
access-list FW2Outside_access_in extended permit tcp any object BW_XSP1_Private object-group DM_INLINE_TCP_1
It should work after this.
Hope that helps.
Varun Rao
Security Team,
Cisco TAC
Thanks, Varun Rao Security Team, Cisco TAC
486
