ASA5510_Ver 8.3 can not forward port
ASA is 5510, ver 8.3(1), I can't forward ports (www, ftp) from outside to DMZ.
My configuration:
outside:  IP Public (X.X.X.X)
DMZ:  10.10.10.0/24
access-list outside-in extended permit tcp any interface outside eq www
access-group outside-in in interface outside
nat (DMZ,outside) source dynamic DMZ interface
object network WEB
  host 10.10.10.5
  nat (DMZ,outside) static interface service tcp www www
asa#sh xlate type static
TCP PAT from DMZ:10.10.10.5 80-80 to outside:X.X.X.X 80-80
asa#sh nat
  (DMZ) to (outside) source static WEB interface service tcp www www
    translate_hits = 0, untranslate_hits = 0
asa#sh access-list
access-list outside-in line 2 extended permit tcp any interface outside eq www (hitcnt=0) 0xacb645cb
Syslog: ASA-3-710003: TCP access denied by ACL from Y.Y.Y.Y/64141 to outside:X.X.X.X/80
ASA# packet-tracer input outside tcp X.X.X.X 80 10.10.10.5 80 detailed
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   10.10.10.0     255.255.255.0   DMZ
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
 Forward Flow based lookup yields rule:
 in  id=0xa88943e0, priority=500, domain=permit, deny=true
        hits=11, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip/id=X.X.X.X, mask=255.255.255.255, port=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
        input_ifc=outside, output_ifc=any
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: DMZ
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
In access-list, I've changed destination to real IP (10.10.10.5) or public IP, the result was the same.
I don't know which mistake in my configuration. Could anyone help me?
Thank you very much for your help.
VIP Purple
The destination address in
The destination address in the ACL has to be the real IP of the server. And upgrade the ASA to something newer. 8.3(1) was probably the worst version ever on the ASA.
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
Dear Karsten Iwen,Yes, I've
Dear Karsten Iwen,
Yes, I've replaced Real IP in ACL, but everything is still the same as before.
I think port forwarding is normally on every firewall, should I upgrade the ASA to newer version ?
VIP Purple
Show your actual config (at
Show your actual config (at least NAT/ACL). And yes, you should upgrade.
Dear Karsten IwenASA's ACL
Dear Karsten Iwen
ASA's ACL/NAT:
ASA Version 8.3(1)
interface Ethernet0/0
 description WAN1
 duplex full
 nameif outside
 security-level 0
 pppoe client vpdn group WAN1
 ip address pppoe
interface Ethernet0/2.5
 description DMZ
 vlan 5
 nameif DMZ
 security-level 50
 ip address 10.10.10.1 255.255.255.0
access-list outside-in extended permit tcp any host 10.10.10.5 eq www
access-list outside-in extended permit tcp any host 10.10.10.5 eq ftp
object network DMZ_NET
 subnet 10.10.10.0 255.255.255.0
nat (DMZ,outside) source dynamic DMZ_NET interface
object network WEB
  host 10.10.10.5
object network FTP
  host 10.10.10.5
  nat (DMZ,outside) static interface service tcp ftp ftp
I 've checked NAT (show nat detail, show xlate,...), translation is OK. DMZ to internet is OK, Internet can ping to outside.
Show access-list:
  access-list outside-in line 2 extended permit tcp any host 10.10.10.5 eq www (hitcnt=0) 0xacb645cb
  access-list outside-in line 3 extended permit tcp any host 10.10.10.5 eq ftp (hitcnt=0) 0xea857100
Packet-tracer:  Web & FTP were dropped at ACCESS-LIST (phase 2 or 3) with Implicit Rule.
Does Implicit Rule concern about NAT?
Port Forwarding is a basic function of ASA, should I upgrade?
Thanks for your reply.
VIP Purple
You object NAT is fine, but
You object NAT is fine, but the following rule is wrong:
That one needs to go to the end of the NAT-List:
no nat (DMZ,outside) source dynamic DMZ_NET interface
nat (DMZ,outside) after-auto source dynamic DMZ_NET interface
Dear Karsten IwenI 've
Dear Karsten Iwen
I 've configured:  nat (DMZ,outside) after-auto source dynamic DMZ_NET interface
the result was still the same.
VIP Purple
did you remove the old rule?
did you remove the old rule? Please show your complete NAT-config.
Sorry Karsten Iwen, I 've not
Sorry Karsten Iwen, I 've not been at work last time.
Yes, i removed the old rule, show nat detail:
Manual NAT Policies (Section 1)
1 (inside) to (outside) source dynamic LAN_NET interface
    translate_hits = 1214968, untranslate_hits = 115784
   Source - Origin: 192.168.100.0/24, Translated: X.X.X.X/32
Auto NAT Policies (Section 2)
1 (DMZ) to (outside) source static FTP interface service tcp ftp ftp
    Source - Origin: 10.10.10.5/32, Translated: X.X.X.X/32
    Service - Protocol: tcp Real: ftp Mapped: ftp
2 (DMZ) to (outside) source static WEB interface service tcp www www
    Service - Protocol: tcp Real: www Mapped: www
Manual NAT Policies (Section 3)
1 (DMZ) to (outside) source dynamic DMZ_NET interface
    translate_hits = 2103, untranslate_hits = 8
    Source - Origin: 10.10.10.0/24, Translated: X.X.X.X/32
I've read Syslog, and realized that something is wrong:
WEB: ASA-3-710003: TCP access denied by ACL from 123.17.96.224/64141 to outside:X.X.X.X/80
FTP:  ASA-2-106016: Deny IP spoof from (X.X.X.X) to 10.10.10.5 on interface outside
With WEB: packet was dropped at outside, but FTP: packet  was dropped  behind outside although they were configured with the same ACL/NAT rule.
Do you know which ASA's functions can affect NAT/ACL ?
Thanks for your help.
65
