ASA5512-IPS-K9 this will works in load balancing
To all Master.
Can this ASA firewall work in load balancing. Can client connect in two ISP simultaneously? Thank you if not let me know more info.
1 REPLY
Hello Francis,
Well as it has been mentioned so many times the ASA does not support PBR but if you configure the right static routing and the right NAT commands you will be able to send some traffic via Differents ISP.
What version are you running and what specifically are you trying to send over each link?
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
169
