ASA5515 QOS with ether channel standard queuing example
hi all,
i am trying to apply some QOS to prioritise VOIP traffic over a VPN to a headend PBX i have found numerous examples of this however they utilise the "shape average" command which after some research is not available on the next gen firewall ranges.
sources here
https://supportforums.cisco.com/discussion/11898311/ask-expert-cisco-adaptive-security-appliance-asa-firewalls-lifeline-todays-data
https://supportforums.cisco.com/discussion/11548991/cisco-asa-861-shape-command-invalid
the suggested work around is
"You can use priority queing on outside interface to set the traffic into different queues and prioritizing delay sensitive traffic like RTP."
my question is does anyone have an example of this configuration in practice to help me grasp the concept
thanks in advance.
Hello, You are right multi
You are right multi processor ASAs do not support traffic shapping to the date. You are left with traffic policing where the configuration is a bit different.
Please use this as a guide and let me know what u need:
https://supportforums.cisco.com/document/7011/asa-qos
Jcarvaja
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
hi Jcarvaja, thanks for
hi Jcarvaja,
thanks for taking the time to respond to my query unfortunately i cannot use the "priority-queue outside" command the only option i have here is to use the management interface.
i believe this might be because i have an ether channel (port channel) configured from x4 interfaces of the ASA5515 to x4 interfaces on the switch stack to trunk multiple VLANS and it expects to see the nameif command configured on the physcial interface which is not relevant in this case.
when using ethernet channel is it possible to use priority queing ?
thanks in advance
my config looks like this which faces the stack
interface GigabitEthernet0/0
 channel-group 1 mode active
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/1
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/2
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/3
 no nameif
 no security-level
 no ip address
interface Port-channel1
 no nameif
 no security-level
 no ip address
interface Port-channel1.3
 vlan 3
 nameif inside
 security-level 100
 ip address 10.0.0.0 255.255.255.0
interface Port-channel1.111
 vlan 111
 nameif outside
 security-level 0
 ip address XXX.XXX.XXX.XXX 255.255.255.X
good afternoon,can anyone
good afternoon,
can anyone help point me in the right direction here
thanks in advance.
Hello Matthew, There are 2
Hello Matthew,
There are 2 ways to configure Priority queuing at the ASA level.
From what I can tell you are trying to use Strict mode. Can you use Hierarchical method:
http://blog.ine.com/2008/09/16/qos-on-the-pixasa-%E2%80%93-part-3priority-queuing/
Let us know how it goes,
Jcarvaja
hi julio,thanks again for
hi julio,
thanks again for responding
the "Hierarchical method" again uses the "shape average" command which is not available in the next gen firewalls which i am using specifically ASA5515.
i could perhaps use the "Standard Priority Queuing" method however as per by previous note there is no option to use "priority-queue outside" as the only interface i see as an option is the management interface i think this is as i am doing etherner channel from ASA to switch stack which expects the nameif commands to be applied to the physcial interfaces.
i can find no reference to using QOS on ASA when using etherchannel which is where the sticking point now is.
if i can figure out how to use QOS whilst using etherchannel i will be able to use the standard queuing method.
if anyone has an example of this it would be greatly appreciated.
That's why I asked you at the
That's why I asked you at the beginning to use policing instead of shapping.
Jcarvaja
hey there, same thing applies
hey there,
same thing applies
if i enter "priority-queue ?" i only get the option of the management interface see attached
service-policy police-priority-policy interface outside
good afternoon,having read
good afternoon,
having read the official ASA manual all examples given use the "priority-queue" command which when using ether channel is not possible
i see on amazon that the new revision of the ASA book is coming out shortly which should hopefully address QOS when using ether channel as i cannot find a valid example anywhere
has anyone activiely configured this in production using the next generation firewalls
96
