06-22-2009 03:52 PM - edited 03-11-2019 08:46 AM
hey all, we originally had a one-to-one static translation from private to public IP. the translation has been removed and the private is supposed to be using the global nat pool. but, for some reason, it is still using the public ip originally mapped to it. we checked show xlate, and the translation is not there. it was verified with a sniffer and indeed it is still using the public ip. any workaround or other way of verifying this besides rebooting the box or doing a global clear xlate? thanks in advance, robert.
06-22-2009 05:39 PM
Hi robert,
Did you do clear xlate after deleting the static nat?
one quick way to clear it without affecting xlate table do clear local-host
show local-host
clear local-host
regards
06-22-2009 05:54 PM
show local host x.x.x.x doesnt show anything. we will try and clear it out anyways. thanks for your help!
06-22-2009 10:57 PM
np.. let us know what was the fix, reboot will never tell us why - reboot as last resort, Im sure clear xlate without rebooting should do the trick.
06-23-2009 09:50 AM
worked great. thanks a lot!!!
