Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
it
Community Member
ASA5520-K8 7.0(6) asdm 5.0 missing Interface configuration commands
I trying set mac address on the interface
<code>
Firewall/admin(config)# interface gigabitEthernet0/2
Firewall/admin(config-if)# ?
Interface configuration commands:
  asr-group        Configure Asymmetrical Routing group id
  default          Set a command to its defaults
  description      Interface specific description
  exit             Exit from interface configuration mode
  help             Interactive help for interface subcommands
  ip               Configure ip addresses.
  ipv6             IPv6 interface subcommands
  management-only  Dedicate an interface to management. Block thru traffic
  nameif           Assign name to interface
  no               Negate a command or set its defaults
  security-level   Specify the security level of this interface after this
                   keyword, Eg: 0, 100 etc. The relative security level between
                   two interfaces determines the way the Adaptive Security
                   Algorithm is applied. A lower security_level interface is
                   outside relative to a higher level interface and equivalent
                   interfaces are outside to each other
  shutdown         Shutdown the selected interface
</code>
I found how to set mac address with command mac-address but I don't have it in there.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa72/configuration/guide/conf_gd/intparam.html
Thank you for any hint how to solve it.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hi ,
As per your query , the MAC address command is not supported on your current version and is available from ASA 7.2.1 onwards .
Check this:-
http://www.cisco.com/c/en/us/td/docs/security/asa/command-reference/cmdref/m1.html#pgfId-2111047
Thanks and Regards,
Vibhor
1 REPLY
Hi ,
Check this:-
Thanks and Regards,
Vibhor
238
